Brake pulling to the right
Old Mar 8, 2013 | 02:39 PM
2lionel's Avatar
2lionel
Hey guys its me again, the other day when I got into my truck 2001 Navi, i was driving along and notice when I hit my brake the whole truck steered to the right. So to test it I took my hands of the steering wheel and it definetly pull one when I am hiting the brake any ideas what that could be? Thanks guys for any assistance with this. BTW and mechanic of these trucks on the MD,DC or VA areas give me a shout.
Old Mar 8, 2013 | 09:57 PM
alloro's Avatar
alloro
Either brake fluid is leaking on the right side, which causes a grabbing effect, or a caliper on the left side is frozen and not grabbing.
Old Mar 12, 2013 | 11:24 AM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy
When my 2001 Expedition did that last year, it was a collapsed brake hose. New hose fixed the problem.
Old Aug 25, 2013 | 01:03 PM
repoinem's Avatar
repoinem
Im having same problem, replaced right caliper and high pressure brake line now the caliper on right is stuck again, this makes 3 caliper in 4 weeks??? Should I be looking into the left side?
Old Aug 25, 2013 | 03:23 PM
alloro's Avatar
alloro
1. Which same problem, bad hose, leaking fluid, pulling, etc?
2. If it's pulling, then which way when you apply the brakes?
3. Did you replace the front or rear caliper on the right side?
Old Aug 25, 2013 | 04:17 PM
repoinem's Avatar
repoinem
when driving it pulls to right also does it when braking. when you are going 30+ it makes a loud humming you can only hear inside the truck. when we jacked the truck up we found that passenger front wheel was seized. so we replaced the caliper and high pressure brake lines. (3rd time now) just 3 months ago we redid the bearing, rotors, ball joints, control arms and tie rods on both sides. then had front end aligned and tires rotated.
Old Aug 25, 2013 | 04:20 PM
repoinem's Avatar
repoinem
and while humming/grinding sound it happening it has a strong vibration that you can feel in the gas and brake pedals and steering wheel. I have to take the truck 300 miles out of town for work in a week and need to figure this problem out.
Old Aug 25, 2013 | 10:31 PM
alloro's Avatar
alloro
When you replaced the calipers, did you clean the slides and make sure the guide pins were lightly greased so the caliper slides fairly easy?
rick
May 19, 2016 07:26 AM
cabloom300
Jan 25, 2015 07:38 PM
JETSLED
Mar 14, 2007 08:33 PM
univers88
Bronco II
Mar 25, 2003 07:30 PM
donna
Jul 20, 2000 11:03 PM
