Battery Cable - Starter Slow Crank
Old Mar 9, 2013 | 07:42 PM
BigBlockF350's Avatar
BigBlockF350
Originally Posted by tempest411
Some kind of insulating heat shield on the starter could be beneficial as well. Or even swapping out the direct drive starter you have to one of the later style compact mini starters. I don't have headers, but I do notice mine starts faster after I did this swap.
Thanks. I've decided I'm going to do up it to a thicker gauge. That may not help the issue much. I know I still need to deal with the heat issue, but the thicker gauge can't do it any harm. Plus the old wire is 25 years old, and it could also have some corrosion in it.
Old Mar 9, 2013 | 07:55 PM
Hopsing69's Avatar
Hopsing69
Battery Cables
You can bet if they are that old they need to be replaced. Going to 2 G will help with voltage drop, and I bet if you strip the cable back you will find it to be a unpleasant sight.
Old Mar 9, 2013 | 08:02 PM
BigBlockF350
Yeah, my voltage drops to 9.18 when cranking... I'm going to check tomorrow on what gauge is used on the older diesels too. Probably 2 gauge, but I'm interested to see.
Old Mar 9, 2013 | 09:41 PM
kermmydog's Avatar
kermmydog
Is that voltage drop when the starter is cold or when it is hot. You can buy heat tape fairly cheap from Jegs or Summit. That would be the cheapest I believe & see if that doesn't solve your issue unless you have heavier cable laying around.
Craig.
Old Mar 9, 2013 | 10:00 PM
BigBlockF350
Craig.
I do have some heavy wire, just have to get terminal ends.
I've seen heat "blankets" for starters from Summit and other places. I think I'm going to throw on some foil tape tomorrow, and maybe try to make my own guard. I think a heat shield/guard would work better than a wrap or "blanket". I've seen the actual heat shields (usually aluminum) from Summit and others, but I have a tight space to fit it so I think I'd like to make my own to ensure a good fit.
I'll try to post pictures of what I do.
Old Mar 9, 2013 | 10:24 PM
kermmydog's Avatar
kermmydog
This is what I was thinking then space isn't that much of an issue. I guess the pictures didn't copy.
Craig
JEGS Performance Products 32075
Lava Exhaust Wrap
2" x 25'
Reduces radiant heat damage
Temperature Rating: 1200°F Continuous, 2000°F Intermittent
Item# 555-32075
Ships Monday
Only $34.99
More Info
JEGS Performance Products 32057
Exhaust & Header Wrap
2" x 50'
Charcoal Black
Item# 555-32057
Ships Monday
Only $39.99
More Info
JEGS Performance Products 32052
1" x 50'
Charcoal Black
Item# 555-32052
Ships Monday
Only $21.99
More Info
JEGS Performance Products 32067
2" x 50'
Tan
Item# 555-32067
Ships Monday
Only $37.99
More Info
JEGS Performance Products 32055
2" x 15'
Charcoal Black
Item# 555-32055
Ships Monday
Only $15.99
More Info
JEGS Performance Products 32065
2" x 15'
Tan
Item# 555-32065
Ships Monday
Only $13.99
More Info
JEGS Performance Products 32062
1" x 50'
Tan
Item# 555-32062
Ships Monday
Only $19.99
More Info
JEGS Performance Products 32077
Snake Skin Premium Exhaust/Header Wrap
2" wide x 25' long x 1/16" thick
Item# 555-32077
Ships Monday
Only $39.99
More Info
JEGS Performance Products 32074
2" x 25'
Silver
Item# 555-32074
Ships Monday
Only $45.99
More Info
JEGS Performance Products 32070
2" x 25'
Red
Item# 555-32070
Ships Monday
Only $45.99
More Info
JEGS Performance Products 32071
2" x 25'
Blue
Item# 555-32071
Ships Monday
Only $45.99
More Info
JEGS Performance Products 32073
2" x 25'
Orange
Item# 555-32073
Ships Monday
Only $45.99
More Info
Top
1 2 3 4 5 Next >>
120 Products Results per Page:
Narrow Results
within heat wrap
by Year Make Model
by PartType
Air Intake Blanket (1)
Arm Sleeve (1)
Auxiliary Heater (2)
Battery Wrap Heat Shield (3)
Burst Panel Wrap (1)
Exhaust Header Heat Wrap (13)
Exhaust Heat Shield (30)
Fire Sleeving (14)
Header Tape (13)
Header Wrap (13)
Heat Blanket (2)
Heat Shield (46)
Heat Shield Tie (4)
Heat Shrink Sleeve (2)
Heat Shrink Tubing (2)
High Heat Spray Coating (5)
Starter Heat Shield (7)
Turbo Blanket (3)
Turbocharger Insulating Kit (3)
Wire Sleeve (14)
by Brand
JEGS Performance Products (18)
Moroso (3)
Mr. Gasket (5)
Painless Performance Products (3)
Russell (7)
Taylor (45)
Thermo Tec (38)
XS Power (1)
by Category
Batteries (2)
Circle Track (41)
Cooling, AC & Heating (9)
Exhaust, Headers & Mufflers (102)
Fittings & Hose (9)
Ignition & Electrical (11)
Mustang & Ford Racing (30)
Safety & Seats (43)
Sport Compact (27)
Switches, Starters & Alternators (3)
Tools & Shop Equipment (20)
by Price
Less than $10 (7)
$10 to $20 (17)
$20 to $50 (69)
$50 to $100 (19)
$100 to $250 (7)
$250 to $500 (1)
Shop JEGS by categories!
Performance Parts
Air Filters & Cold Air Kits
Apparel
Batteries
Bracket Racing
Brakes & Drivetrain
Cams & Valvetrain
Car Care
Chassis, Steering & Suspension
Chrome, Billet, Dress-Up
Circle Track
Collectibles, Books, DVDs, Toys & Games
Computer Tuning
Easy Kits
Engines & Components
Fasteners & Gaskets
Fittings & Hose
Fuel, Carbs & Intakes
Gauges & Tachs
Gift Certificates
Hoods, Scoops & Body
Jeep Accessories
Jr. Dragster
LS / LT
Mopar Performance
Oil System
Safety & Seats
Shifters
Sport Compact
Superchargers, Turbo & Nitrous
Timing Chains & Pulleys
Trailer, Towing & Winches
Transmission & Drivetrain
Truck Accessories
Wheels & Tires
Lava Exhaust Wrap
2" x 25'
Item# 555-32075
Only $34.99
2" x 50'
Charcoal Black
Item# 555-32057
Only $39.99
Old Mar 9, 2013 | 10:27 PM
BigBlockF350
Yeah, I've looked at header wraps. Almost did it about 6 months ago. If a heat shield doesn't do the trick, I'll try it.
Thanks!
Old Mar 15, 2013 | 05:31 PM
BigBlockF350
Put some shiny aluminum tape around the starter, and it helped it to deflect heat a little bit. I got some thin aluminum to try to make a heat shield with.
Old Mar 16, 2013 | 01:27 AM
superb68's Avatar
superb68
I had this problem with my 90 F250 with the 5.8. Heat shields on the starter did not help. header wrap on the exhaust didn't work. Finally out of desperation I ran a battery cable directly from one of the starter mounting bolts, directly to the frame. That was about three yrs ago havent had a problem since.
Old Mar 16, 2013 | 05:54 AM
BigBlockF350
Thanks. Might just try that. I can keep my timing set low and "hot starts" aren't an issue. It's just an issue when I have the timing set how I like it.
Old Mar 17, 2013 | 08:02 PM
BigBlockF350
Going to be running a ground wire from starter to frame, and a heavier gauge hot wire to the starter. Also going to make an aluminum heat shield for the starter.
Just a little of the ton of stuff I have to get done on the truck, lol. Also have to replace power steering pressure hose and work on the back brakes. I'll probable put in a PS fluid cooler too since I got one for free that's like new. I'll probably be replacing the tranny cooler soon too. Got so much to do.
Old Mar 17, 2013 | 08:10 PM
kermmydog's Avatar
kermmydog
Smile
The best tranny cooler I have ever used is the B&M SuperCooler. They are small with High BTU cooling & fairly cheap. The ones I have bought were $50.00. I have owned three of them two on Chevy Blazer 4x4 & one on a Jeep GC 5.9 Limited.
Craig
Old Mar 17, 2013 | 08:22 PM
  #28
BigBlockF350
Craig
Thanks! That's the one I was going to pick up. The one I've got leaks a tiny bit. Doesn't leak enough to drip on the ground, but it stays wet with tranny fluid. Not a big deal, but I'd like to have a new one.
Kjreed2087
Nov 18, 2017 07:48 PM
Pokey11
Nov 11, 2010 01:16 PM
2pazr
Feb 19, 2009 02:09 PM
gordo350
Nov 19, 2004 06:22 PM
rosa70
Oct 5, 2004 11:09 AM
