hey guys i hate to even ask this.... but can you hook the wires up wrong on the gpr ? i got power on one big post all the time... than the other big post and little post is hot when the key is on......i got a wait to start light.... but not seein my volts move and cant hear them click.... this is a new gpr i got the big one from mouser..... thanks for the help guys
Check both big posts for voltage with key on and see if it is closing.
Think he already did that ...
No, not really ... two big wires and 2 small wires?
If you had a voltmeter you could look for voltage drop across the relay. Maybe short across big terminals on the relay with a screwdriver with someone in the cab to see if gauge goes down.
If it still doesn't do you know that you glowplugs are good?
yeah gp are new gpr is new batts are new..... the old worn out gp and cpr clicked and you could see the volts drop.... maybe this is just what it dose all new...
