White Smoke
Old Dec 2, 2010 | 05:10 PM
tbone heller's Avatar
tbone heller
White Smoke
My 97 F-Superduty 5-speed is blowing a lot of white smoke in lower gears & above 2000 rpm. A few weeks ago I replaced the fuel pump because it was leaking & replaced the o-rings in the fuel canister. The fuel canister was full of all kinds of crap. If something got into the fuel pressure regulator, could it cause this? The truck idles & runs good. It has no cold start problems. I just finished up my 6.0 innercooler installation & noticed this issue. Could the moving of the hose for the MAP sensor to the hot side cause this?
Old Dec 2, 2010 | 06:35 PM
427 fordman's Avatar
427 fordman
Have you ever replaced the injector orings?
Old Dec 2, 2010 | 10:09 PM
tbone heller
No. I bought the truck used & it has 146,000 miles on it.
Old Dec 3, 2010 | 06:24 AM
427 fordman
Sounds like that's the issue to me. Hopefully someone else jumps in to back me up or correct me if I'm wrong.
Old Dec 3, 2010 | 06:32 AM
jchosler's Avatar
jchosler
It's either the O-rings or the turbo burning oil. My turbo burns a little oil blowing white smoke. Not doing anything about it cause I plan on an upgrade soon
Old Dec 3, 2010 | 07:22 PM
tbone heller
Just by-passed the innercooler by installing the stock turbo outlet manifold. The smoking problem has gone away for the most part. The hot side innercooler pipe had no signs of oil in it so I do not think that my used innercooler is full of oil. I will try attaching the MAP hose to the hot side & see what happens.
Old Dec 3, 2010 | 09:21 PM
FARM69's Avatar
FARM69
How much smoke does she put on the first cold start of the day? I'm not talking about a bad glow plug or two...If she's putting out more than normal I would bet it's the injector o-rings.
Sounds like o-rings to me...
Old Mar 8, 2013 | 09:16 AM
tbone heller
I know that it has been over 2 years since I had this white smoke issue. After the removal of the innercooler, all smoking has stopped completely for over 30,000 miles. I really would like to add some additional power since 99% of my driving involves towing.What would I need to go along with the 6.0 intercooler/Banks twin ram manifold set-up as far as a chip is concerned?
Guzzo
Dec 8, 2013 12:46 PM
adarkang
Nov 10, 2010 04:11 PM
true blue
13
Jan 4, 2007 01:12 PM
my93
Jan 8, 2005 12:32 AM
crandall
Jul 23, 2000 12:13 AM
