GPR what now?
Old Dec 30, 2008 | 09:52 PM
theenforcer's Avatar
theenforcer
GPR what now?
hey guys
i fitted a L.E.D to my GPR yesterday,cool mod and found that my light doesnt work, i sort of hijacked another GPR thread yeasterday (sorry bout that) and got a bit of feedback as to what to do (thanks tristan). i grabbed the multimeter from the yard and a length of wire to check if the LED was faulty.
checked the LED all good, put the multimeter on and nothing, i even checked the relay next to it, i think is the AIH one if im correct and nothing there either, i checked the hot side of both and had a reading of 12.5v the same as the battery. could both of these relays be stuffed, i have only had trouble starting it about 3 times in nearly 4 years, thoes times have been 0 degres or less, but after swiching the key off and trying the 2nd time she fired up.
is there anything else i can check guys to make total sure they are no good before i fork out for some new ones.
thanks in advance
josh
Old Dec 30, 2008 | 10:13 PM
triskit16's Avatar
triskit16
Ok, first, you did you check the voltage on the GPR with the key on right?!
Old Dec 30, 2008 | 10:19 PM
theenforcer
yeah sure did mate had the missus turn on the key while i had the multimeter in the post just incase it turned off real fast
triskit16's Avatar
triskit16
Secondly, heres a picture...the nut that the arrow from is ontop off from "GPR" is where you need to be testing and connecting the LED as well. Now if youve done everything correctly thus far someone else will have to chime in. I would suggest changing the GPR but if you checked something else as well and it didnt work, Im just not sure!
Old Dec 30, 2008 | 10:24 PM
theenforcer
yeah thats the post i checked off and i also did the same for the identical relay next to it, thinking if i got a reading off that one i was going to just swap them over, but yeah got nothing from that one either.
thanks for your help mate well get to the bottom of it soon
Old Dec 30, 2008 | 10:27 PM
triskit16's Avatar
triskit16
They sell the GPRs at NAPA...but I dont know what chain parts stores you have down under!
Old Dec 30, 2008 | 10:35 PM
theenforcer
yeah i dont know if they will have them on the shelf out here, might be a dealership thing which scares me a bit but ill look around and see if i can source some.
yeah we dont have NAPA stores, i've got a local parts dealer that looks after me cause im in there all the time buying stuff, i'll try him and see how i go...
Old Dec 30, 2008 | 10:42 PM
theenforcer
where can i find the part number on the relay, at least if i give him that he might be able to match some aftermarket ones for me.
thanks guys
Old Dec 30, 2008 | 10:43 PM
triskit16's Avatar
triskit16
Well if worse comes to worse, just buy a Stancor GPR. Do a search for it and you will get the right model number. It will be around or cheaper than the OEM from the dealer and people swear by them! It goes in sideways or some weird way but it bolts in there and you wont have to replace it EVER again! Its a BEEFY monster! That way you wont have to worry about it and if your GPR DID work its another mod you have!
Old Dec 30, 2008 | 10:46 PM
theenforcer
yeah sweet tristan i saw thoes big berthas i'll look them up
cheers mate
josh
Old Dec 30, 2008 | 10:49 PM
triskit16's Avatar
triskit16
I dont know if you have an International dealer down there either....but if you do and ever need anything for this engine tell them you have a T444E....if you say 7.3L they will say restricted to ford only! (most of the time)
check this site out...it will tell u part numbers and install
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Old Dec 30, 2008 | 11:00 PM
theenforcer
cool thanks mate yeah theres a inter dealer just up the road, thanks for the info, i'll give them a try to.
