DELO 400LE ?
Old Mar 6, 2013 | 08:20 PM
F3504ME's Avatar
F3504ME
DELO 400LE ?
My usual oil is 15-40 Shell.... WM had none so I picked up some Delo 400LE.
Is this OK for one oil change interval? I have read the SJ is not as preferred as the SL for our trucks..
Old Mar 6, 2013 | 09:28 PM
Shake-N-Bake's Avatar
Shake-N-Bake
That oil will work just fine.
Old Mar 7, 2013 | 03:53 AM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
My truck has been ran on Delo 400 since it's second oil change, except for a couple changes which I used Valvoline. It has 242,000 original miles on stock injectors, HPOP, turbo, etc...
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Mar 7, 2013 | 05:59 AM
hammer65's Avatar
hammer65
Your oil choice will be fine, as mentioned above.
But the service designation you should be looking for is CH4 or CG4. Not SJ/SL which is a spark engine designation, but some oils cover both.
Just a thought. Jim
Old Mar 7, 2013 | 06:34 AM
koski19's Avatar
koski19
I've been using Delo400LE since 2005 when I bought my truck an E99.
266,500 miles and great oil reports back from Blackstone. It's ok to use.
WM usually has the best price about $12.99 a gallon on sale.
Jeff
Old Mar 7, 2013 | 07:34 AM
rufushusky's Avatar
rufushusky
Delo 15W-40 is a CJ-4/SJ rated motor oil. The "C" ratings (aka compression based ignition) are the ones you want to pay attention to.
Anyways Delo is a fine consumer grade motor oil and will handle anything rotella handled IMHO. I actually have that in my truck right now.
Old Mar 9, 2013 | 08:58 AM
F3504ME's Avatar
F3504ME
Good morning all. I do appreciate all the info and education... 400LE it is.... curious as to why they have two formulations? I understand the LE is for the DPF based vehicles and backward compatible... but why offer two? is the standard non LE based oil better for our engines?
Old Mar 9, 2013 | 02:07 PM
rufushusky's Avatar
rufushusky
Fuel standards are not the same over the world, US and the EU have ULSD for the most part (15ppm) but countries like Russia, India and China have diesel fuel with 500-5000 ppm of sulfur, which is not what CJ-4 oil was designed to handle. With ULSD, a CJ-4 oil will be fine. If you run LSD (500 ppm), which unless your fueling up in rural siberia you aren't going to find much of it, then a CI-4+ oil with its slightly higher TBN amounts would be a better fit. Other than that, IMHO, there is no benefit to running a CI over a CJ unless your planning on running 25k OCIs.
Old Mar 9, 2013 | 02:48 PM
white Buffalo's Avatar
white Buffalo
Seen some excellent Used Oil Analysis reports from 7.3L's running the Delo LE. You are good to go........
Old Mar 24, 2013 | 08:40 PM
BWST's Avatar
BWST
Got Data?
My first foray into synthetic engine oil will be Delo 400LE, picked up some today - Like F3504ME, WM was out of Rotella T6. Good to hear it is an option for our rigs. I imagine I'm competing with several other diesel truck owners in the Seattle area for the limited WM shelf space for this product. Sucked the old dino out of the HPOP as well and topped off with Delo. We'll see how she does. I had been running Motorcraft 15W-40 dino.
Old Mar 24, 2013 | 08:55 PM
nlemerise's Avatar
nlemerise
That is 5W-40 correct?
Old Mar 24, 2013 | 09:47 PM
BWST's Avatar
BWST
Got Data?
Right, the Delo is 5W-40. Was running 15W-40 dino.
Old Mar 25, 2013 | 08:48 AM
nlemerise's Avatar
nlemerise
Thanks Jeff, have you seen the 0W-40 Delo LE up there?
Old Mar 25, 2013 | 10:19 AM
BWST's Avatar
BWST
Got Data?
I haven't. I was looking for any 5W-40 or 0W-40 to compare, but only found the Delo 5W-40 that day.
tampacamper
6.7L Power Stroke Diesel
15
Nov 17, 2010 09:00 AM
Kenworth
Aug 3, 2009 09:56 PM
pete88
22
May 9, 2009 11:09 PM
Shanemh
May 26, 2008 10:28 AM
hitecdan
Oil & Lubrication
Oct 27, 2003 04:07 PM
