Oil change
Old May 25, 2008 | 02:47 PM
Shanemh's Avatar
Shanemh
Oil change
I have heard so many different things on the different brands of motor oil. I usually use penzoil but is there a major difference in other brands and which are considered better?
Thanks, Shane
Truck has 71,000 miles
Old May 25, 2008 | 06:18 PM
BChance's Avatar
BChance
welp.. check out the oil forum..it's fun sifting through the opinions...my current truck had 126,000 when I got it, Pennz and Fram @5k intervals it's entire life..it was not horrid inside.. no sludge, but a pretty heavy varnish. I ran some seafoam in the crankcase for a little while, and switched to Royal Purple, with Pure 1 filters, and it is beautiful inside now at 145,000.
If you change your oil at a reasonable interval, with almost any quality oil, it will be fine.
Old May 25, 2008 | 06:20 PM
danr1's Avatar
danr1
<i>If you change your oil at a reasonable interval, with almost any quality oil, it will be fine.</i>
Ditto that.
Old May 25, 2008 | 06:23 PM
khadma's Avatar
khadma
Carpenter Local 745
Walmart sells Motorcraft oil filters for 4.00 or less.
I use Castrol in my higher mileage trucks, Walmart's Supertech is also affordable and made by a brand name manufacturer - but I can not remember which one - Quaker?
Old May 26, 2008 | 10:28 AM
jonpfeifer's Avatar
jonpfeifer
all oils have to meet a minimum standard and as long as you keep on top changing the oil you should good.
