78 f350 camper special rear tank
My rear fuel tank needs replacing and of course no replacements are available. Short of getting a custom built tank, what are my options? Truck is a 78 f350 reg cab 2wd camper special powered by a 1989 460 efi....my stock tank is modified to accept the in tank fuel pump as well, and has the California evap.
Looks like you have some options here "F350" gas tank | eBay
Edit also see here http://www.rockauto.com/catalog/x,ca...,parttype,6268
That's a "Non-sequiter".. a Latin term which means "A conclusion or statment that does not logically follow from the previous or proceeding statement or argument".
It's a custom application so there is no replacement for it except to use a stock replacement tank and modify it for your custom application.
make sure the one you get is for the narrower frame rails your truck has.
the frame rails on your truck should be the same dimension as a cab-chassis trucks of that era. so if you find one that is made to fit a cab-chassis it should fit as well.
the 34-3/4" looks right, but you'll want to double check.
My aft axle fuel tank needs replacing and of course no replacements are available. Short of getting a custom built tank, what are my options?
Truck is a 78 F350 Regular Cab Camper Special (140" wheelbase) powered by a 1989 460 efi.
My stock tank is modified to accept the in tank fuel pump as well, and has the California Evap/Em.
1978/79 F350 Regular/Crew Cabs and Regular Cab Camper Special on the 140" wheelbase.
D8TZ-9002-S .. Aft Axle Plastic Fuel Tank-20.6 Gallon Capacity-Use without Evap/Em / Obsolete
1978 F350 Regular/Crew Cabs & Regular Cab Camper Special on the 140" wheelbase.
No Ford Dealer or obsolete parts vendor has either one.
33 1/2" distance between the inner frame rails behind the cab:
1973/77 F250 4WD (High Boys) / 1973/79 F350 Cab & Chassis / 1973/76 F350 Super Camper Specials / 1977/79 F350 Regular Cab Camper Specials on the 140" wheelbase.
Ford dropped "Super" after 1976 / All other 1973/79 F350's: 37 1/2" distance between the inner frame rails behind the cab.
If Highboy width applies then any rear tank Highboy solution applies https://www.ford-trucks.com/forums/1...l#post12853911
You may find your EFI solution with later bronco II also
http://www.rockauto.com/catalog/x,ca...,parttype,6268 1984
!987 fuel injected same dimensions http://www.rockauto.com/catalog/x,ca...,parttype,6268
Jazz fuel cell
How about that Jazz fuel cell Grinner used,summit or Jegs
<TABLE id=ncode_imageresizer_warning_13 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20></TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
the 87 bronco II fuel tank is for fuel injected motor and dimensions
are the same as the one used as a Highboy tank
1987 FORD BRONCO II Fuel Pump
1987 FORD BRONCO II Fuel Tank Sending Unit
habbythetabby
01-27-2019 10:31 AM
ACME Garage
12-01-2018 10:42 PM
dtupper1
12-21-2016 09:41 AM
