tail gate latch
Old Mar 6, 2013 | 07:25 AM
bigb56's Avatar
bigb56
tail gate latch
My latch broke in the closed position. Is it possible to remove the access panel while the gate is closed, or is it possible to open the gate some other way?
Old Mar 6, 2013 | 10:34 AM
Brother Les's Avatar
Brother Les
take the panel off and you can reach in and unlatch it. A new latch is easy to replace if the cable or a part broke.
Old Mar 6, 2013 | 02:34 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
No cables in the tailgate, metal rods with JC clips to hold them to the handle and the latches. To much plastic in the latch assembly for my taste, but what can you do.
While in there you might want to hook up a electric tailgate lock solenoid, I have one and it locks the tailgate when the doors lock so you can keep a turd from stealing your tailgate.
Old Mar 6, 2013 | 03:28 PM
nlemerise's Avatar
nlemerise
Tell me more Mr CHiPs!
Old Mar 7, 2013 | 01:44 PM
truckeemtnfords
I forget the manufacture but I bought it a Summit. It attaches to the latch assembly inside the tailgate. You have to run two wires out of the tailgate that tie into the door lock wires so that everytime you lock the doors it locks the tailgate and does the same for unlock. I put a small connector on mine at the rear of the truck so when I pull the tailgate for the camper I don't have to cut wires. Love it because if the truck is locked so is the tailgate to keep it from getting stolen and no fumbling with keys to lock/unlock the tailgate.
Old Mar 7, 2013 | 02:51 PM
nlemerise's Avatar
nlemerise
Dave, is this it?
Old Mar 7, 2013 | 06:44 PM
Crashman927's Avatar
Crashman927
I wish somebody would steal my tail gate...word of advice - open the tail gate when unhooking the 5th wheel (long story)
This lock will be going in the new tail gate once I get it painted..Thanks for the post
Old Mar 7, 2013 | 07:18 PM
bigb56's Avatar
bigb56
When you install the power lock whatt happens to the hole where the key cylinder was? Camera?
I did the hose clamp mod for now.
Old Mar 11, 2013 | 01:12 PM
truckeemtnfords
Neal, different manufacturer but same type set-up.
Big, the outside of the latch stays the same, lock, camera handle all remain as is and still function. Just like having power door locks, you can still use your key if you lose the remote or just want to use your key.
Bluegrass F250
Sep 3, 2020 10:45 PM
conchstew
Aug 21, 2012 01:25 PM
Big Drex
1997 - 2003 F150
Feb 19, 2006 07:11 PM
RedClifford
1997 - 2003 F150
Sep 30, 2004 06:59 PM
sternal2000
Mar 19, 2003 05:03 PM
