Sponsored by: Auxito
Snapped Tailgate Cable
Old Feb 19, 2006 | 06:32 PM
Big Drex's Avatar
Big Drex
Red face Snapped Tailgate Cable
Cant get tailgate to open now. What is the step by step way to replace my tailgate cable? Any help for a DUMMY like me would be MUCH APPRECIATED
-Drex
Old Feb 19, 2006 | 07:06 PM
LxMan1's Avatar
LxMan1
There should be an access panel on the inside of the tailgate to get to the latch assembly.
Old Feb 19, 2006 | 07:11 PM
triton_2002's Avatar
triton_2002
Not sure I understand your question. The cables support the tailgate then opened, the tailgate should still open without the cables, unless they somehow are jamming the latch. If you pull on the handle and it won't open, most likely the linkage inside the tailgate is missaligned or broken. There is an access panel on the inside of the tailgate but not sure if you can take it off with it in the closed position. Do you have a lock on the tailgate? Sometimes it has a tendacy to lock on it's own when you slam it closed.....just an idea....hope that helps.
