IAT Sensor
Old Jun 1, 2003 | 02:53 PM
1stBronco's Avatar
1stBronco
Question IAT Sensor
What does the IAT Sensor do? I saw a modfication to a replace this with a resistor (100K), to improve engine performance and gas mileage by making the engine believe the air temp is 32 degrees. Could this cause any improvements or problems with the engine?
Old Jun 1, 2003 | 10:29 PM
mach'er's Avatar
mach'er
IAT Sensor
IAT = Intake Air Temperature
The engine's computer knows the temperature of the air being ingested into the manifold's plenum. It then modifies the spark, and a few other things, to account for the actual conditions going on - including the IAT reading.
If you trick the IAT into reading cooler, you'll be advancing spark based on a cold intake charge. If you don't mind buying premium fuel, and can live with a little detonation... It could also change the open loop to closed loop fueling transition, resulting in overly rich for extended periods.
Yes, you COULD get a little more power, but their are definately downsides which should be considered.
Old Jun 2, 2003 | 05:50 AM
1stBronco's Avatar
1stBronco
Smile IAT Sensor
After reading this again, I thought this might b to good to be true for daily driving. But, had to ask.
Old Jun 2, 2003 | 10:08 PM
jbabbler's Avatar
jbabbler
IAT Sensor
I will say this, though, If you cut one of the wores leading to the IAC and splice in a 5.6kohm resistor, you will see some pretty good gains. If it doesnt ping, double that till it feels right. This way the IAT will still adjust for different temps, your truck will just think its 20 degrees colder.
Flash635
18
May 7, 2014 12:53 PM
SHOOTER22250
May 15, 2013 06:53 PM
tictx
Mar 27, 2011 07:37 AM
southern hunter56
Mar 23, 2011 04:20 PM
PeterSr
Jan 12, 2011 08:20 PM
