Becarefull with the clip don't bend it out too far it will snap, there's two wires and a ball looking thing attached but you have to get thru the soot first, sorry I cant remember the wrench size off hand , threads in the Manifold
Just went out with my fluke meter and tested continuity in the maf harness, the 2 pins that dont have burn marks and then the third next to it ring out while set to battery ground...
the truck is warm right ? these are base values koeo
IAT1-98.6
IAT2-113
have you ever sprayed the maf with anything? there's a MAF spray that's suppose to be used.
I Think so IAT1 would be from cold side and 2 would be Manifold I did read that iat1 controls a lot more than we think timeing for one and air/ fuel ratio for timeing I would think that if iat1 was shorted that's where the connection burnt, but I've been known to be wrong before twice this year so far
So the question is, which one is correct. What is the ambient temp during these readings? 3 is pretty cold man. Seems to me that the sensor in the intake manifold is your culprit, not the MAF/temp sensor.
