Surging idle after long highway trips?
#46
#47
Its still doing this...took a 3 hour round trip yesterday and as soon as i got back into town it was surging/choppy idle again. I have Auto Enginuity now, dont really know how to use it to its full extent, but lemme know what readings i can data log and post up for you guys to see whats going on
#48
ICP volts
IPR
VGT
Map
Baro
EBP
Iat1
MAF
Josh
#50
Without going back thru the pages, when it surges have you tried disconnecting the MAP sensor while it is surging?
Josh
#51
#53
I have not. MAP has the tube running from the intake manifold correct? Something i did notice while swapping out my air intake was the connector for the MAF sensor id say about 3/4 of the face of the connector was burnt...i checked out the MAF sensor itself and all the pins are fine
Disconnecting the MAP electrical connector sends the PCM into default. I would be curious if the surging stopped with it in default.
Josh
#55
Also, its been doing something else for a while, which i have a really hard time describing and literally cannot catch on video because its so random... but its almost always going from drive to reverse, when i first press the pedal in reverse it romps a few times unless i give it more throttle or let off. you can feel the whole truck shake when it does this. id say about 75% of the time its when i go from drive to reverse, sometimes itll do it in drive taking off but not nearly as much.
#59
Thats totally random temps, sometimes itll do it switching to reverse to back out of my driveway after a cold start, other times itll do it after driving 25 minutes and backing into a parking space. its noticeable enough that some friends at school usually ask me about it
And yet another thing that may be related is since its cold now and goes into high idle to warm up, when i hit the brake to switch into gear and the idle drops back down, it doesnt drop back down very smoothly. Rough idle for a few seconds after leaving high idle
I dont have an egr cooler or valve, and its fully turned off in my tune. Also it doesnt do the romp thing in stock as far as i know, but it does it in 3 different tunes, from 3 different tuners.
By throttle valve do you mean the thing in the intake elbow? If so, then no, its gone and replaced with a newer style intake elbow
#60
