Surging idle after long highway trips?
Ill add another piece to the puzzle (that hopefully doesnt come back)
Drove 25 mins to school, no surging or running weird or anything, and then it sat for 2 hours. Came back out, waited for GP light to go off, and started to crank...and crank...and crank...for like 10-15 seconds before i gave up. Turned key off, back on and then it fired right up. Didnt happen to catch the ICP value. Although i stopped 10 minutes after driving to get a drink and then it started up quick and ICP was 1400psi starting
i have not done that yet, mostly because its way back there. its such an intermittent surge is it going to run great if i unplug it, even if its not surging? it seems to idle/run fine otherwise, just a random surge
i did have an ICP code a while ago, that hasnt come back. P2287
just checked to see if i had any new codes, just P0687, which i had the other day and apparently hasnt gone away
From my notes:
P2287 ICP Injector Control Pressure Sensor Circuit Intermittent ICP signal is intermittent
I don't have P0687, maybe it was P0678
P0678 GPCM Cylinder 8 Glow Plug Circuit Open circuit, short to ground, short to voltage, glow plug
It is just a glow plug code and should not cause the problem you are having.
<table style="width: 681pt; border-collapse: collapse;" border="0" cellSpacing="0" cellPadding="0" width="908"> <colgroup><col style="width: 77pt; mso-width-source: userset; mso-width-alt: 3730;" width="102"> <col style="width: 86pt; mso-width-source: userset; mso-width-alt: 4205;" width="115"> <col style="width: 237pt; mso-width-source: userset; mso-width-alt: 11556;" width="316"> <col style="width: 281pt; mso-width-source: userset; mso-width-alt: 13714;" width="375"> <tbody><tr style="height: 12.75pt;" height="17"> <td style="border: 0.5pt solid black; width: 77pt; height: 12.75pt; background-color: transparent;" class="xl66" height="17" width="102">P2287</td> <td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 86pt; background-color: transparent;" class="xl66" width="115">ICP</td> <td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 237pt; background-color: transparent;" class="xl65" width="316">Injector Control Pressure Sensor Circuit Intermittent</td> <td style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: black black black windowtext; width: 281pt; background-color: transparent;" class="xl65" width="375">ICP signal is intermittent</td> </tr></tbody></table>
I cant find a P0687
could it be a P0678 that a Glow plug DTC
Ya I dont see 1 GP causing this
I think Cheezits Right on the Money with ICP or ICP Wiring issue or Chaff
The P2287 is more likely it and maybe the DTC hasnt came back since its not Failing Every drive cycle
Post ICPV at KOEO and Make shure to leave it on the gauge so you can check ICPV next time it acts up
Did it again today. Had driven it upto temp about 30 mins, came home and parked and went out about an hour later. But i just let it crank to see what happened, probably 10-15 seconds and then it started and ran fine. Going out to program ICP voltage into scangauge now
Also when it started, i felt a big thump in the floor boards?
