DEF Fill Problem
Old Feb 23, 2014 | 09:30 AM
  #31
U235Fishin''s Avatar
U235Fishin'
Originally Posted by ForemanES
I wanted to share my experience with you guys for anyone that may have similar problem. .....
I just wanted to share this with you guys to avoid not having to go to the dealership if you encounter the same thing. If it wont take any DEF smack it around a little bit
I guess I need to drive MORE rough New Mexico roads to make sure that the DEF tank and appurtenances get some vibration to keep things loosed up. I haven't had a problem with this phenomena yet. Seriously, thank you for posting this information. What do Chrystal's buddies say about this? Anyone know?
Old Feb 23, 2014 | 04:55 PM
  #32
caverjoe's Avatar
caverjoe
Originally Posted by senix
I was down to 300 yesterday and added 5 gallons. I think you have a problem.
Right... that is the way it went the first 2 times I filled it. Both times I ran it down pretty low like 100 or less till E. It seemed to hold around the 4.5 mark both times. but not this time. If it does it again guess it will need to go back to the steelership. Less than 14k on the Odometer right now.
Old Feb 24, 2014 | 07:34 AM
  #33
ForemanES's Avatar
ForemanES
Glad I saved a few folks from going to the dealer
I haven't had this problem again since this happened last year but wanted to share more of the back story.
I was in CO the week prior with <-0*F temps BUT I had been home and in above freezing temps and up to 80*F. I'm still guessing I overfilled the tank before we left and it froze something up in the filler neck.
Old Feb 25, 2014 | 05:18 PM
  #34
caverjoe's Avatar
caverjoe
Hmmmm been pretty cold here and I am sure I overfilled both times I filled. Cause the first two times i was using the bottle before I knew about the truck stop. I could not get 5 gallons in either time, but sure tried prolly 4-4.5 max.. but if it happens again it is going back to the steeler. but I only have 14k on since I bought it last of Oct.
PwerStroke99
Nov 5, 2016 09:31 AM
bulla
Oct 28, 2011 09:34 PM
KC8QVO
6.7L Power Stroke Diesel
17
Oct 6, 2011 09:19 AM
thegreytruck
Apr 30, 2007 12:06 PM
