Carberator/Balancer issues...HELP!?
Old Mar 3, 2013 | 10:44 AM
AfFORDablility's Avatar
AfFORDablility
I have an 84 E150 with an 81 302 5.0 from an F-150 under the hood. This project has been a pricey headache from the start. I am now trying to select the correct/economically sensitive/performance enhancing Edelbrock or Holley carb. As this rig is equipped with O/D, I've learned it requires a Lokar throttle cable bracket, but does it require an Electric or Manual choke? I am looking at an Edelbrock 600 CFM. Any and all help is appreciated...thanx.
Old Mar 3, 2013 | 12:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's determined by which carb you install. If you install one with an electric choke then you don't need a mechanical choke. If you install one with a mechanical choke you will need to install a cable so you can control the choke from inside the van.
dkf
Oct 3, 2008 09:07 AM
sum_weirdo
Nov 4, 2007 05:28 PM
wheressinatra
16
Jan 10, 2007 03:01 PM
BlazerLT
May 18, 2005 12:06 AM
learpilot
Jul 15, 2004 05:58 PM
