transfer case
Old Mar 3, 2013 | 07:48 AM
Bad 674x4's Avatar
Bad 674x4
transfer case
I have a hi-low and hi-low lock transfer case what do the hi-low lock do?
Old Mar 3, 2013 | 05:20 PM
Ford_Six's Avatar
Ford_Six
It sounds like you have an NP-203 case, which is a full time 4x4 setup. The regular high and low are with the power going through a center differential, supplying both axles but really all the power will go to whatever tire has the least traction. The lock positions lock the front and rear axles together giving actual four wheel drive.
Old Mar 3, 2013 | 05:23 PM
1972RedNeck's Avatar
1972RedNeck
What transmission do you have? It could be the wrong **** on lever.
Old Mar 4, 2013 | 07:24 AM
Bad 674x4's Avatar
Bad 674x4
Just got the 67 truck a 67 cab on a 1992 1-ton 4x4 frame
Old Mar 4, 2013 | 07:26 AM
Bad 674x4's Avatar
Bad 674x4
Will go out and look
Old Mar 4, 2013 | 08:17 AM
crazed87bronco's Avatar
crazed87bronco
Lets see pics of the truck sounds interesting
nate5812
Apr 5, 2005 02:20 AM
funnyboy
Jan 31, 2005 08:00 PM
tothfngclw
1978 - 1996 Big Bronco
Sep 11, 2002 02:12 PM
Boss_358
Offroad & 4x4
Jan 31, 2000 06:40 AM
