Sponsored by: Auxito
Urgent help please
Old Mar 2, 2013 | 09:57 PM
brandon19's Avatar
brandon19
Urgent help please
so i bought my f150 from a dealership i replaced the fuel pump but when I was driving home one night my truck decided to **** on me I got dashes in my odometer its not reacting to my fuel pump im not getting voltage im lost and need help my theft light is flashing when I turn my keys my gauges go down
Old Mar 3, 2013 | 07:25 AM
enriched&beyound's Avatar
enriched&beyound
Several things possible;
You might be having a issue with PATS system. If you got another set of keys with your purchase... try the other set.
your alternator needs to be checked for proper output.
your battery need to be load tested.
check all connections, & grounds, make sure they are good.
might be that your relay to the ECM is bad too or any relay or fuses to ECM or fuel pump
Old Mar 3, 2013 | 08:16 AM
steve(ill)'s Avatar
steve(ill)
theft light flashing and gauges dropping is a good sign the PATS is not working. Godd chance is the truck thinks the ignition key is wrong. Try another key or have dealer flash computer for a new key if you dont have a spare.
Old Mar 3, 2013 | 12:26 PM
brandon19's Avatar
brandon19
okay i pulled the pats
SnowHiker
2004 - 2008 F150
Jan 31, 2018 07:18 AM
scottperkins
1997 - 2003 F150
Oct 15, 2015 06:06 AM
9902ford
1997 - 2003 F150
16
Jun 4, 2013 06:20 PM
RST1000
1997 - 2003 F150
13
Feb 5, 2008 03:16 PM
1990f1504x44.9
1978 - 1996 Big Bronco
Dec 18, 2006 11:10 PM
