egr
Old Mar 2, 2013 | 11:21 AM
dullybob's Avatar
dullybob
egr
what is the first sign of a egr cooler going bad my temps are only 4 degrees apart
Old Mar 2, 2013 | 11:47 AM
dannyboy950's Avatar
dannyboy950
Well ya said it yourself. The increase in the temps. Primarilly the delta or temp differential between the ECT reading and the EOT reading.
The coolant temp and oil temp difference. A delta of 15*deg. greater temp difference between coolant and oil is almost a shure of a restricted [plugging] oil cooler.
Old Mar 2, 2013 | 12:05 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The EGR cooler can fail catastrophically or it can start degrading to the point it should be replaced during other work. Sometimes the first sign of failure is a massive cloud of white smoke dumping out of the truck, sometimes it's a wet EGR valve, sometimes it's the temp delta, sometimes it's a chocolate milkshake in the degas bottle, sometimes it's a hydrolocked motor. If the EGR cooler completely lets loose it's probably because of a clogged oil cooler, but if you have a wet EGR valve it could just be leaking slightly even if you currently have a good temp difference. On a used truck if the oil cooler was replaced but not the EGR cooler, the EGR cooler could easily start leaking with an acceptable temp variance of less that 15*.
Kind of depends on what the order of failure is; the oil cooler blocking coolant flow, the EGR cooler packed up with carbon build up, stuck EGR valve, etc. There's not one definitive root cause that applies to all cases, even though the oil cooler is the most common one.
Old Mar 2, 2013 | 03:30 PM
dullybob's Avatar
dullybob
my temps has never change water level never changed today i ran the **** out of it still no changes and never smoked it seems to do it when i start it cold but goes away im leaving for daytona thrusday hauling friends and my bike down last thing i want is to brake down
Old Mar 2, 2013 | 05:07 PM
m-chan68's Avatar
m-chan68
If the ambient temperatures are very cold where you are, it's not unusual for your truck to smoke a little white during takeoff when the engine is cold. It the symptom disappears once it's up to operating temperature, I would call it normal.
Old Mar 2, 2013 | 05:08 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
My egr cooler crapped out a couple months ago with deltas of 7-9 consistently. It ruptured causing a hydrolock. I pulled it and plugged and welded the ends plus removed the scoop from the up pipe. Got her back together finally and running good. Only have put about 250 miles on it since I got her patched up but deltas are still good. Didn't change my oil cooler due to the good deltas so I hope that don't bite me later. Left valve plugged in and so far no CEL. Mines an 05.
Old Mar 2, 2013 | 05:15 PM
dullybob's Avatar
dullybob
yeah its been very cold and after about 2 minutes no smoke whats so ever but to be honest i never notice or look all winter
Old Mar 2, 2013 | 05:28 PM
dullybob's Avatar
dullybob
oh one thing i never notice till this week and last week i put t-6 in last week
Old Mar 2, 2013 | 06:02 PM
dullybob's Avatar
dullybob
truck starts right up weather i plug it in or not , and is very smooth
Old Mar 3, 2013 | 11:01 AM
dullybob's Avatar
dullybob
today i hooked up my trailer drove 35 miles down rte. 11 to the ohio river and back up .no smoke no temp change ran great now going to clean it and get ready to load 4 bikes and off to daytona
shayne.jacques
Apr 1, 2015 08:19 AM
Grant-Dieseltech
Nov 22, 2014 12:05 PM
Hurricane67
Oct 7, 2011 09:27 PM
akalogan
Jan 11, 2011 12:56 PM
Wrapn3
Jun 24, 2010 07:59 PM
