6.0L DEGAS PUKE
Old Mar 31, 2015 | 10:29 PM
shayne.jacques's Avatar
shayne.jacques
6.0L DEGAS PUKE
Okay so my degas puked a few times. Under the egr valve is wet. I have a scanguage2 that I constantly keep an eye on between water temp and oil temp. They are always within 5-8* from each other once warmed up. If i run the truck hot the biggest difference might be 10-11* max. So i guess i don't know if I'm dealing with a bad egr cooler or head studs or both.
Old Mar 31, 2015 | 11:32 PM
jswartz84's Avatar
jswartz84
If it's wet under the egr valve you have a busted egr cooler. I would try not to run it until it's repaired. Its easy to turn this situation from a couple hundred dollar fix to a couple thousand dollar fix.
Old Apr 1, 2015 | 12:07 AM
shayne.jacques
Ok ill order a egr delete kit right away. I presume ill have to do a new oil cooler also?
and thanks for the input
Old Apr 1, 2015 | 12:12 AM
jswartz84's Avatar
jswartz84
If the largest difference is 10-11°, I probably wouldn't replace the oil cooler. Make sure you are determining the difference correctly though. A good test is flat driving, unloaded, engine completely up to temp, after 15 minutes traveling @ 65mph.
Old Apr 1, 2015 | 08:19 AM
KDAVID1's Avatar
KDAVID1
What he said. I just finished a delete due to puking. Had the hunch it was egr cooler but no wetness for me--just puke. Luckily for me it was just that. No puke since egr cooler is now out and all is well.
2006 F350 4X4
Waterlogged
Mar 5, 2016 12:56 PM
05 f250 6 inch lift
Jun 3, 2014 04:54 PM
dullybob
Mar 3, 2013 11:01 AM
Cryobossman
Dec 25, 2012 08:22 PM
akalogan
Jan 11, 2011 12:56 PM
