Cargo light switch
Old Mar 1, 2013 | 10:05 PM
dp045's Avatar
dp045
Cargo light switch
How can I put the cargo light on an up-fitter switch so it comes on without any other lights? I have a 2012 F-350.
Old Mar 2, 2013 | 05:09 PM
Franklin2's Avatar
Franklin2
Intercept the wire coming from the light, cut it, and then extend it with a new wire to one of the upfitter switches.
Old Mar 2, 2013 | 06:21 PM
dp045's Avatar
dp045
Thanks, that won't set off any warning sensors saying I have a light out will it?
Old Mar 2, 2013 | 06:42 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You can find out easy enough....pull the bulb and see if it sets a warning.
Old Mar 3, 2013 | 10:55 AM
SteveC7010's Avatar
SteveC7010
It's possible to do this without losing original function, ie, cargo light on with open door or whatever. By adding a diode, he can just "T" the upfitter switch and have the best of both.
upfitter switch ------------------------------|
factory line to cargo light -----------diode----|-------cargo light
Diodes that can handle a few amps are readily available at Radio Shack.
One caveat, however: Remember that the upfitter switches are hot only during run/accessory. If the key is off, the upfitters are off.
Old Mar 3, 2013 | 06:37 PM
dp045's Avatar
dp045
Thanks again. I wonder why I didn't think of this?! I'll try it out.
Old Mar 3, 2013 | 06:43 PM
dp045's Avatar
dp045
Thanks. Sounds like a good idea. I like it.
sgeorge
Jan 7, 2018 05:24 PM
jarnold60
Mar 18, 2008 03:41 PM
n9lhm
Nov 14, 2005 11:17 PM
77hiboyboy
Jan 16, 2005 06:14 PM
plumr
May 6, 2002 01:09 AM
