Is there any way to wire up the dome light, or the cargo light on a switch?? So I could have the cargo light on while the dome light is off, or have the doors open without the cargo light on?? There are times when I need to be able to sneak around and be able to get out without having my cargo light come on. Thanks in advance-Aaron.
They just run the same wire to the cargo light.It would be a job to do what you want.
Do you have map lights up there cause that means that there is power there all the time. At least you wouldn't have to run a power wire all the way up there. you could break the wire going to the cargo light and put it on one of the map light switches.
pulling the map bulb. Or drilling and putting a small switch in there for the cargo light
3 way sw one way would be on center off and other side could be normal.
