Sponsored by: Auxito
Spare Tire Lock?
Old Mar 24, 2009 | 10:41 AM
KingRanchMan02's Avatar
KingRanchMan02
Originally Posted by Anythinggoes
Ya, I called to buy the factory lock assembily kit that fits in the key hole of your bumper and the parts guy asked if I was sitting down before telling me the price. My friend has one on his truck and it isn't much more than a gun lock that goes on the trigger hole on a revolver. He told me they sell for 95 dollars. Ha, no wonder people don't replace them. I came on hoping I'd find one for around 30 or less. If you've got big money go for it, I'll pass and keep on looking.
I've got a spare factory lock kit if you want one that I will sell for $30 plus shipping. PM me if you are interested. It is referenced as 1A380 in this link.
https://www.ford-trucks.com/forums/7...ml#post5944810
Old Mar 24, 2009 | 09:05 PM
Anythinggoes's Avatar
Anythinggoes
Thanks John and I'm going to try to drop the tire down by Thursday to see if the unit works. My truck is a 2004 FX model and the hole for the rod is on the right of the liecence plate. I don't know that much about the lock kits, but do you think it would fit my model? If it does, I'm interested in buying it. Phil
Old Mar 24, 2009 | 11:20 PM
2002 F350V10's Avatar
2002 F350V10
I am sorry but all you guys are not thinking about life in the big city. Factory lock? forget it, you would be less 1 tire in seconds here. Cable lock? think again, the thieves have better cutters than most. The only thing left is this. You need to chain the tire through the frame with a square link hardened chain. the padlock (which would be quite heavy duty and a major label) would slip through one lug nut hole also. then if the padlock is installed with antisieze and tape to cover it from debris.
I have that on 1 truck. The other truck I improvised using new (since i am a car wash mechanic) C188 welded pin car wash conveyor chain , and the linking pin is a long shackle heavy duty padlock with the exposed shackle side facing up.
You have to lasso it and make it so visible and difficult so they move on and leave you alone.
Old Mar 25, 2009 | 09:39 AM
KingRanchMan02
Wow, you must live in a rough part of Chi-town! Most of us don't have to contend with that level of thievery. The factory lock prevents the lowering handle from being inserted into the winch that holds it up under the bed.
I am sure that the winch is the same under your truck. The lock device snaps into the slot that the handle goes into. Then it requires the key to be on the end of the handle to allow the winch to work.
Old Mar 25, 2009 | 08:13 PM
2002 F350V10
In the city you need to fortify your things or they will grow legs and walk away. Having had several cars stolen in the past, you will find a layered security atmosphere works best. The factory tire lock is childs play for the pros. You need to get a great hard to cut substantial chain and a major brand lock and make the thief really work if they want to try stealing your tire. Usually they pass and move on down the road to easier prey. Quite often someone visits the town from other areas and within hours they lost the tire. Happens every day here , many times a day.
pappy19
General Automotive Discussion
Feb 19, 2013 08:50 AM
hoff4052
Feb 21, 2012 09:18 AM
stacy h
Jan 18, 2012 09:41 PM
elmo
1997 - 2003 F150
Jun 14, 2004 11:23 AM
mach'er
Jun 1, 2003 06:27 PM
