Sponsored by: Kumho
spare tire lock
Old May 31, 2003 | 09:04 PM
mach'er's Avatar
mach'er
Question spare tire lock
The spare tire was stolen from my 2001. Monday, I pick up a new 2003 FX4 - is there a reliable product that will prevent a repeat of the stolen spare?
Thanks.
Old Jun 1, 2003 | 08:00 AM
AlabamaBronco's Avatar
AlabamaBronco
spare tire lock
found these by doing a search for "spare tire locks".
http://www.autotoysfx.com/products/p...=1054472684218
Hope it helps.....
West
Old Jun 1, 2003 | 02:28 PM
rebocardo's Avatar
rebocardo
spare tire lock
It depends on how the tire is held up to the bed or frame. The thing that works the best is to have a piece of threaded grade 5 rod through the wheel lug hole and attach a wheel lock to it. Does the tire lower through a wire/crank system under the tailgate?
Old Jun 1, 2003 | 03:58 PM
mach'er's Avatar
mach'er
spare tire lock
Yes, it is the system that has a hole in the rear bumper, put the rod from under the hood in there, crank away, and lower the wire/tire.
Old Jun 1, 2003 | 06:27 PM
bronco351's Avatar
bronco351
spare tire lock
I have an easy solution. It does cost a little more but it's well worth it. All you have to do, is buy a really sensetive alarm system. This way if someone so much as touches your truck the alarm will go off. For my BRonco, I bought a Prestige alrarm system. It uses 6 speakers. Also it makes 5 different sounds. It did cost me $525.00 installed. I think it was well worth it!!
deshet1980
Oct 19, 2014 06:35 PM
hoff4052
Feb 21, 2012 09:18 AM
garymocwi
1983 - 2012 Ranger & B-Series
Jun 3, 2005 08:56 PM
groge71
Mar 5, 2005 05:43 PM
tolvibman
Bronco II
Jul 3, 2002 05:25 PM
