lift kit
Old Feb 28, 2013 | 07:59 PM
alexisvfd's Avatar
alexisvfd
lift kit
I have a 04 250 and I have 2inch blocks already. Idk if they came stock or not but I want to got 3 inch higher to fit 35's. Can I just order 5inch blocks if so what all Will I have to change
Old Feb 28, 2013 | 10:09 PM
BLADE35's Avatar
BLADE35
Best to get the Whole Kit
You would need Shocks with More travel
I beleive my Leaf springs were changed To its a 6 inch lift
And the Sway bar Mount deal changed
Do you have Coil or Leaf springs in the front?????
Get the Lift Kit you will need everything in it and will make it easiest as there is Alot more to it than Blocks
Old Mar 1, 2013 | 08:50 AM
alexisvfd's Avatar
alexisvfd
Leaf. you remember how much you paid and where you got everything
Old Mar 1, 2013 | 09:49 AM
Diablo540's Avatar
Diablo540
Just put a 4in lift on wifes bronco springs in front blocks in rear from rough country job was easy if you have the right tools i did it in driveway it took 2 weekends due to worn out parts i came across and had to order otherwise if yours is in good shape and you have some mechanical back ground should be able to do it in about 4-6 hours i think i spent around 500-700 $ somewhere on the kit shipped to the house. If you want rear springs instead of blocks be ready for another couple hundred dollars. Roughcountry.com or google rough country
mustang81
13
Nov 26, 2019 08:02 AM
Lightning LA
Mar 22, 2018 10:41 PM
LCrowe2012
Feb 25, 2014 01:59 AM
F 250 6 liter
May 21, 2011 08:55 AM
FortyFords
Nov 22, 2002 09:53 PM
