400 camshaft?
Old Mar 2, 2013 | 11:30 PM
bigperm2's Avatar
bigperm2
for the compression and camshaft duration thing, its a matter of dynamic compression ratio. I am not a great expert at this, but if you google it you will find a lot of info on it. If you have a motor with low compression and a high overlap (lope), the overlap bleeds off a bunch of the peak cylinder pressure, and the motor is a dog. This is because it has no bottom end since the cam makes its power at high RPM, and it has no top end because it doesn't have the CR to make good peak cyl pressure. There are problems with high compression and a short duration cams too. The cylinder pressure at low RPMs without the overlap, causes detonation and dieseling.
Old Mar 3, 2013 | 12:54 AM
privateer, eh's Avatar
privateer, eh
Go to the 335 engine forum and read the first, read first. You'll find 2 articles concerning compression and detonation and pre ignition. they,re under the following
The power squeeze
Engine basics: detonation and preignition
Say thanks to crsmiffy for finding and presenting these articles
Ford77Pickup
22
Jan 12, 2024 09:21 AM
liljerry
1978 - 1996 Big Bronco
Mar 1, 2013 06:58 AM
etnies13
Mar 16, 2009 07:06 AM
75crewcab
Jul 20, 2007 02:35 AM
mrsuperman15
Dec 7, 2003 11:11 PM
