1978 - 1996 Big Bronco
cam in 400?
Old Feb 28, 2013 | 02:07 PM
liljerry's Avatar
liljerry
cam in 400?
I have a Ford 400 in a 78 bronco. I'm planning on putting an intake carb camshaft and probably headers on it. You guys got and suggestions on brands and models I should use? Thanks
Old Mar 1, 2013 | 06:07 AM
udsuth78's Avatar
udsuth78
if your installing a new cam i suggest upgrading your valve springs also. the stock ones wern't great new and yours are 35 years old, plus there only good for about .500 lift. you will also want to upgrade the timing set while your there since the M block engines were retarded from factory. a straight up set will help alot. as for which cam i've read alot of people running comp cam high energy and xtreme energy lines check summit's website.
FORD 6.6L/400 Ford Modified Camshaft and Lifter Kits - SummitRacing.com
maybe one of these
COMP Cams High Energy Cam and Lifter Kits CL32-219-3 - SummitRacing.com
COMP Cams High Energy Cam and Lifter Kits CL32-221-3 - SummitRacing.com
COMP Cams Xtreme Energy Cam and Lifter Kits CL32-241-4 - SummitRacing.com
Old Mar 1, 2013 | 06:58 AM
liljerry's Avatar
liljerry
Ok thanks for the help
dittohead
Mar 14, 2015 10:54 PM
turbocadxxx
30
May 11, 2009 04:42 PM
etnies13
Mar 16, 2009 07:06 AM
mstum00
Jan 10, 2005 09:46 PM
rogue69
Jun 6, 2003 08:26 PM
