Front 05+ light sockets
Old Mar 1, 2013 | 02:35 PM
wrxin's Avatar
wrxin
Originally Posted by Apocalypse
Fit was perfect, love the lights but you either have to swap the header panel or cut the OEM one. Don't cut, it's WAY to much work.
Thanks! Much appreciated.
Old Mar 1, 2013 | 08:01 PM
saz2686's Avatar
saz2686
The 90 pulls off the socket, and the straight socket slides in it's place. I really can't explain how. I stuck a small flat head driver in one side and pushed and pulled and the 90 came off. Don't be forceful and break it! It is designed to come apart.
Old Mar 1, 2013 | 09:13 PM
Apocalypse's Avatar
Apocalypse
Went and tried to mess with it just now and can't find it in the dark I'll get it in the morning Thanks!
Old Mar 3, 2013 | 11:29 AM
garryk6's Avatar
garryk6
My 05 lights came with their own sockets that were different, but all I had to do is unplug th pigtail from the old light socket, and plug to the new...
Did your lights come with their own?
Garry
Old Mar 3, 2013 | 01:57 PM
Snowseeker's Avatar
Snowseeker
Garry
The more I think of it, I believe that is what I had to do and just didn't think much of it. My 05's came with everything in them even headlights.
Old Mar 3, 2013 | 06:53 PM
Apocalypse's Avatar
Apocalypse
Mine had the headlight bulb but none of the others
Old Mar 6, 2013 | 07:20 PM
tturbonegro's Avatar
tturbonegro
I had to use the old socket in my new headlight..I just put the new bulb in the old socket, the other side the old plug went right into the new socket
But the other side worked with the new socket that came with the new headlights
Old Mar 7, 2013 | 07:05 AM
Snowseeker's Avatar
Snowseeker
I wonder if it has to do with if you cut out your 99-03 panel to fit the headlights or if you get the 05+ header panel to fit the lights.
If it is all cut out to fit the lights I bet the original strait sockets would probably still work. With the 05 header panel it may not clear the strait sockets.
Old Mar 7, 2013 | 08:10 AM
Apocalypse's Avatar
Apocalypse
I have the 05+ panel, but the problem is with the light housing, that's what's keeping the socket from going in.
Supercab
16
Jun 1, 2015 08:50 PM
ericconn
Sep 5, 2013 12:55 PM
oilyowl
Jun 11, 2007 11:55 PM
josh84
2004 - 2008 F150
Oct 30, 2006 02:49 PM
sdpj
Sep 17, 2005 11:05 AM
