Sponsored by: Real Truck
parking lights
Old Sep 17, 2005 | 12:36 AM
sdpj's Avatar
sdpj
parking lights
ok, just upgraded to 02 and up headlights and turn signal assemblys. noticed tonight that the turn signal on my left one would work just fine but the parking light on that side would not work, theres only one bulb in there so whats going on. does the bulb just need to be replaced? thanks for the help guys.
Old Sep 17, 2005 | 08:05 AM
mastercaster's Avatar
mastercaster
most likely is the bulb. there will be 2 elements in the one bulb. change it.
Old Sep 17, 2005 | 08:55 AM
Steve_250's Avatar
Steve_250
Put a meter on it and see if you get a connection.
That will rule in or out the bulb.
Old Sep 17, 2005 | 11:05 AM
Rongold's Avatar
Rongold
Talking Parking Light
The bulb in there has 2 filaments--one for the parking light and one for the signal. Once you get the socket assembly out, put a rag around the bulb just in case it breaks, and just pull it out of the socket. push the new one in--orientation does not matter. Your problem should be solved.
RON
