How I got my truck to weigh 3980 lbs...
Old 02-27-2013, 03:29 PM
crazy96863's Avatar
crazy96863
crazy96863 is offline
Yes... California and its DMV can suck it... To hell with their weight fees. Commie *******s.
Here are a couple pics if it helps... I did have to cut the exhaust off from the back of the cab to make this work.
Feels really light... I removed about 300lbs or so of stuff. Fortunately this is a one time event.
Old 02-27-2013, 03:42 PM
wilcam47's Avatar
wilcam47
wilcam47 is offline
you should make a palette flat bed just for them, make the tail lights functional and attach license plate
Old 02-27-2013, 06:04 PM
crazy96863's Avatar
crazy96863
Haha. Yeah. If I ever try to get it down to 2980 (the scale measures in twenties) (This is the next tier down in weight class) I might try that... Not sure if between the bed and the doors I could get it that low and I don't have much else to remove while keeping it drivable unless I put a 4 banger from a ranger in it to save 500lbs from the 390, np435, and the transfer case. I think that would be going a bit extreme.
Gotta know when to be happy with what I got. This saves me about $55 a year on registration. Going a tier down would only be another $20. It can be done but not really worth the effort. This took all of an hour to tear down and another hour to put back together.
Old 02-27-2013, 10:45 PM
privateer, eh's Avatar
privateer, eh
privateer, eh is online now
My 78 f350 long wheel base dually is on a diet, but when I scale it, it while be in running weight. When I started, Henry weighed 7910 with $10 of petrol in him. I'm aiming for 5900 with both tanks full, all spare tires and everything else I'll need. Except cats.
Old 02-27-2013, 10:46 PM
crazy96863's Avatar
crazy96863
Where are you gonna find 2000 lbs to gut?
Old 02-27-2013, 11:18 PM
jgavac's Avatar
jgavac
jgavac is offline
Probably a few hundred in the flatbed, take off the outer dually wheels, bumpers, have only minimal fuel... All I can think he would be able to do
Old 02-27-2013, 11:27 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,317 Likes on 2,467 Posts
Scribe the door hinge position and pull'm and yea on the bed too. Put a sheet of 1/8 plywood on it, hang your tail lights, have it on E fuel wise and borrow some stock rims with little tires.
Old 02-27-2013, 11:33 PM
crazy96863's Avatar
crazy96863
Haha... I'm not going that low. I was having to pay $80 extra each year due to weight... Now its $24. This update is FOREVER. That takes the edge off.
Maybe I should fill the tires with helium.
Old 02-28-2013, 01:15 AM
privateer, eh
I bought a 89 f350 short wheelbase dually, 351w efi, zf42 5 spd. $450. The body was crap but the rest is good. Once I've changed the cab I'm scaling the cab & chassis with 800lb on it to represent the fuel weight. (front tank is almost full now). Then I'll start weighing things like buddies aluminum rims & tires, my steelies,etc and start taking it from there. I know theres a shorter drive shaft available and that might be the next wheelbase if I know for sure I'm not going to make weight.
that deck had a 7.5'x 11.5' 3/16" plate over 2x6 t&g over 2x3 c channel ribs on 2x6x 12' rails plus the subframe for the hydraulics x 2 pcs and all the outside frame / dress up metal. Thats my project metal now.
Old 02-28-2013, 10:44 AM
kevin316's Avatar
kevin316
kevin316 is offline
Sounds like a lot of work for $55. My time it takes to do all that is worth more than $55.
Old 02-28-2013, 11:28 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
I'm glad I live in Missouri and don't have to deal with all that.
Old 02-28-2013, 08:37 PM
privateer, eh
I'm just trying to save fuel when I go on tour with my 5th wheel, if I could get it down to 4900 I would, but I ain't paying to take off weight. No Jenny Craig for me.
Pokiejoe
1999 to 2016 Super Duty
05-17-2017 07:41 PM
corman146
03-05-2016 08:50 PM
flixden
2009 - 2014 F150
27
03-28-2012 09:34 AM
BioHazrdMan
28
12-15-2009 06:35 AM
mc
11-10-2004 04:59 PM
Quick Reply: How I got my truck to weigh 3980 lbs...
