HPOP Output fitting question
Old Feb 26, 2013 | 08:59 PM
OldBlackCat's Avatar
OldBlackCat
so im fixing to make a order at riffraff diesel, for a fuel bowl o-ring kit and a stock of fuel filters. while i have the bowl out im going to tighten my hpop output fittings up as one of them is seeping again and the o-ring is most likely trashed. i tightened it a while back but not as solid as id like because of fuel system parts in the way.
im currious as to what the difference between the check valve and non check valved fittings is?
Riffraff Diesel: Ford HPOP Outlet Hose Fitting
Riffraff Diesel: HPOP Outlet Hose Fitting - Non Check Valve
just curious as to the difference. most likely just gonna order the o-rings for the fittings and get that slight oil leak stopped.
Old Feb 26, 2013 | 09:18 PM
Chris123NT's Avatar
Chris123NT
One has a check valve whereas one doesn't. I know when I installed my adrenaline pump the instructions specifically stated NOT to re-install the check valves because the pump internally balances pressure across both heads. Not sure if you can eliminate the check valves on a stock pump but I don't see why you can't.
Old Feb 26, 2013 | 09:35 PM
Shake-N-Bake's Avatar
Shake-N-Bake
The OEM pump will work just fine without the check valves. I suspect the valves might be a carry over from the time when the reservoirs didn't have the standpipe.
Hotairjunkie
Apr 23, 2024 04:33 PM
logangg
Oct 29, 2016 10:25 AM
Spktyr
Jan 31, 2016 07:30 PM
James Shook
May 25, 2014 01:03 AM
jkh04200
Jan 11, 2007 06:40 PM
