Fuel pump priming
Old Oct 28, 2016 | 09:34 PM
logangg's Avatar
logangg
Trailering
Fuel pump priming
I have a 89 F250 with the 5.8 engine. When I bought the truck I had to clean the fuel tanks, installed all new fuel pumps, and filter, new pressure regulator, and cleaned the fuel rail and installed new injectors. After all that I still have to prime the truck four or five times before it will start. What do I need to do to fix this problem? Any help would be appreciated.
Old Oct 29, 2016 | 08:26 AM
subford's Avatar
subford
Sounds like the high pressure pump on the frame check valve is not holding or the new pump does not have one.
Old Oct 29, 2016 | 10:25 AM
logangg's Avatar
logangg
Trailering
If it is the check valve, would I have to buy another pump or can I just buy a check valve?
Hotairjunkie
Apr 23, 2024 04:33 PM
Connecticut Calvin
May 9, 2019 09:13 AM
TMattson
Jun 7, 2009 05:53 PM
MRCONCDID
Jul 28, 2007 01:18 PM
Norm Carter
1978 - 1996 Big Bronco
Jul 7, 2004 03:05 PM
