Parts Help Please
Old Feb 26, 2013 | 10:47 AM
Chevmn56's Avatar
Chevmn56
Parts Help Please
1978 F250 4x4 400 Manual
1. Do you know how the oil dipstick tube is sealed into the oil pan??? Is it compression or O-ring, or threaded or both ???? mine is gooped up with silicon and i can not tell.
Are the oil tubes still available?? If so where!
2. I am getting ready to re-tape my harnesses and have noticed they have retainers (black or white) that are taped into the harness to aid in routing. Why are there two differnet colors? The harness that has the black retainers is not original to my truck (mine had all white). And where in the hell can i get these retainers???
3. I was reading prior posts learning as much as i can, i ran across a post that mentioned dealer installed A/C, this is a pic of what the guy posted
Click this bar to view the full image.
I have the same unit, in the post a part/or engineering # D1FZ-19A551-A is that for the whole bezel, is any or all of this bezel available????
Thanks a lot Pat
Old Feb 26, 2013 | 11:10 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Not sure how the dipstick tube is sealed.
Tube assy., oil level indicator
77-up F150-350 4WD w/ 351M-400
D7TZ-6754-A
Unfortunately no dealer or obsolete supplier has one.
The wire retainers are available from Dennis Carpenter Dennis Carpenter Ford Car, F-100 Pickup Truck, 8N, 9N Tractor and Cushman Scooter Restoration Parts
Wire retainer, C7AZ-13A506-S $2.00 ea. (they're white)
Old Feb 26, 2013 | 11:23 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's the illustration of the A/C.
The part number you listed, D1FZ-19A551-A, is for the "Ford" logo on the name plate.
The entire bezel assy. is p/n D4TZ-19C784-A
Fits: 73-up F100-250 with integral dealer installed A/C w/o hang on glove box
Unfortunately no dealer or obsolete supplier has one of these either.
File Type: pdf
Old Feb 26, 2013 | 11:30 AM
HIO Silver's Avatar
HIO Silver
D7TZ-6754-A
It's an interference fit at the oil pan.
On auto trans, they typically have an o-ring.
Old Feb 26, 2013 | 12:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks HIO. I knew the tubes were an interference fit for the 2WD pans because they're installed in the block. But because the tube goes into the pan on 4WD I wasn't sure. I've seen some Fords where the tube screws into the pan.
When I install the tubes in the block, I use a thin coating of Permatex #2 sealer on the end of the tube to help prevent leaks.
Old Feb 26, 2013 | 01:54 PM
Chevmn56's Avatar
Chevmn56
Don't mean to sound stupid........ but what do you mean by "interference fit" ?????? Ill take a stab at it..... just a metal in metal fit ????? that might explain why the silicone BALL around the bottom!!
Old Feb 26, 2013 | 01:59 PM
Chevmn56's Avatar
Chevmn56
Oww ya Thanks for all your help its truly appreciated.
Old Feb 26, 2013 | 04:43 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yeah, it's metal to metal. The ID of the hole and the OD of the tube are almost the same. You should need to tap the tube in place. If it just slides in without any resistance, the interference fit is gone.
In this application I don't like using silicon. I prefer Permatex #2, this is a non-hardening sealer and works better than the silicon.
Old May 14, 2024 | 10:38 AM
Swillie1251's Avatar
Swillie1251
3rd Gear
Dipstick tube on 400
I had my 400 pulled out to put in a f100 and while it was out i went ahead and redid all the gaskets timing chain and so on. I pulled the dipstick tube from the block and it was a real tight fit. I figured it had some kind of seal/o ring and it did have one now I can not find a replacement for it and the dipstick tube is loose. Went to parts store called ford and they all act like I'm retarded when I tell them it had one in it. Has anyone else ran into this and if so were you able to get a replacement?
Old May 14, 2024 | 09:07 PM
tbear853's Avatar
tbear853
Never mind .... just saw is ancient.
Old May 16, 2024 | 03:37 PM
Swillie1251
3rd Gear
yes I went through that one already on the 86 4×4, the one on the 400 I am talking about is a 2wd f100 and it has a front sump oil pump and the dipstick tube goes through the block right behind the alternator.
kheisler
16
Feb 29, 2024 12:28 PM
VictorwithaC
Jun 24, 2017 03:10 PM
Baddhabit
Jun 11, 2016 08:56 AM
Undertheoaks
Apr 7, 2014 01:36 PM
jk_hooper
Jul 2, 2009 06:28 PM
