Swappin' or choppin'
1. Could/Should I swap in the Dana 70? It's a factory Dually . . . . might work?
2. Definitely do the well documented (here) brake booster swap into the 72.
3. I can't use the Factory A/C, but I got the '73 running today (smooooooth) and can hear what I think is the air compressor building pressure and then the 'Pssst' like it has reached psi limit . . . . so now I'm thinking about an on board air system using the cast iron behemoth a/c compressor and putting it in my 72 4x4. Has it been done? Can it or should it be done? Hmmm.
4. Since I use my 72 4x4 for hauling firewood why not add in the leaf pack along with the Dana 70 rear off the 73 F350 . . . possible?
5. I wonder what other cool stuff I could steal off this 73 F350 for my 72 to make it better. The front disc brakes are all new on the 73 but it's a 4x2 so it doesn't look good for a bolt up.
Or, do I pull the motor and part out all things not necessary and scrap the rest?
Cheers, Hello, and thanks for your input. My first post after a year of reading all through this forum (but surely not all of it).
No reason you couldn't use the 70 rear. Driveshaft length will probably be different and you might want to measure the spring pads, they might need moved. Also since the brakes are probably bigger on the 70, you might have to fiddle with the brake proportioning.
While 90 psi isn't a lot, it should function for what I would need out in the boonies (Flat tire, blow the junk out of my chainsaw's air filter, etc.). I have been saving one of the stainless steel water type fire extinguishers for use as an air tank. Read a thread a couple years ago on a 4x4 site about how to plumb one etc. Should fit nicely inside the frame rails. Do you know if the person that used the AC compressor ever wrote about how he did it on a forum etc.?
I was wondering about the oil as well, the manual mentions that in normal operation the oil can circulate in the AC system and then return to the pump . . . sounds like magic.
Definitely looking at the Dana 70 on the rear, although I must confess that I'm in a real jam and just have to get the F250 running so I can go cut some fire wood. If the 70 looks like a fairly easy swap I'll just do it, but I may have to wait until money starts flowing to do much more than a bolt on deal. It's also got 3.73 gears and an open diff which I'd want to change to a true track or some such and put in lower gears . . . more money.
Here's an important distinction/question: Since the Dana 70 is set up for Dual wheels and since I am NOT running duallies on my F250, when I bolt up my standard SRW rims to the Dana 70 It's possible my track width in the rear could change some . . more homework for me. Any favorite suppliers of rims with different backspacing etc.? Now I have to learn that lingo as well.
Brake proportioning. I must admit I know absolutely nothing about that. Are there actual adjusting screws? I'm trying to recall if my truck has the arm connected to the frame to self adjust in some mysterious way the brake pressure at the rear brake line manifold when more weight is in the truck . . . can't recall which old truck I had did that. If you could elaborate a bit that would be good.
York Compressor for On-Board Air
Cheers.
Thanks.
