Bad Injector?
Old Feb 25, 2013 | 07:30 PM
fd1109's Avatar
fd1109
Getting ready at the end of March to pull motor for a oil pan change , while I have it out where I can get to everything easy I,m going to give it the once over . I see where someone said if engine has over 200,000 the injectors are just about ready to replace . Mine has 246,000 seems to be running ok with a litttle problem cold start ( checked everything seems ok ) do you think a total replacement is necessary for all eight injectors ? ouch !! any advise on cost or oem or aftermarket ? If I got to do it , it will be easyier while I have the engine out where I can stand next to it instead of laying up on it !!! Thanks Dean
Old Feb 25, 2013 | 09:06 PM
JMP E350's Avatar
JMP E350
"Mechanic" put the petal to the floor and it blew white smoke..
Says ..Up misfire on cyl 5.. See Ya .. WHAT????
Did the truck warm up ? Whats the temp in OK right now??
If you let the truck warm up .. other then burning a little oil does it seem to run OK and get you around ?
If your getting a hesitation/ virbation/misfire when its cold add a bottle of seafoam to the engine oil to thin it out.. 15-40 take a while to move when its cold..
It wont hurt... see if this helps the misfire...
Monitor engine oil every day so you know exactly how much it burns and when...
(write it down in a book!) Note when its smoking....
Burns when hot. .. burns when cold... smokes only at start ?? all this is helpful !
Old Feb 25, 2013 | 10:03 PM
JT250's Avatar
JT250
Actually getting some snow currently but we have been in the 30's and 40's lately. 20"s in northwest OK but just a trace in OKC. Possibility of 3" overnight but I doubt it. Everything (schools) closed early today because we were supposed to get snow. People freak out here.
Old Feb 25, 2013 | 10:12 PM
brendanmitchell's Avatar
brendanmitchell
Originally Posted by Tugly
So... you just want to get this running good enough to put on CL? Do you have a need for a bad-*** diesel, but maintaining it is too costly? Did this look appealing and you really like it, but you don't have the resources or the need for such a beast? Am I warm on any of these? This is not prying, this is my style of trying to learn what you really want to do about the truck and there are plenty of good people here to offer up useful input. Our input will be based on your true motivation.
I got the truck because it was what I was used to driving back home in Indiana. Regular cab 3/4 ton truck. I found this one, and I couldn't pass it up. It did help that it was the 7.3L as well. The only difference now is that, yes, I'm the one who has to maintain it, it's not my dad's truck. Sounds bad of me, like I was given everything, but this is actually the only truck I've ever owned myself. It is a little costly, though, I can't lie about that. I hope that helps out? Thank you.
Old Feb 25, 2013 | 10:14 PM
brendanmitchell
Originally Posted by JT250
I live in OKC I think I am the only one with AE around here.
If you want we can try to meet sometime to.check it out.
Maybe these guys will make a list of stuff to loom at so I don't miss anything.
That would be awesome if we could get it checked out sometime. Do you live anywhere close to Tinker AFB?
Old Feb 25, 2013 | 10:18 PM
jkidd_39's Avatar
jkidd_39
Hopefully someone on here w/ an AE can do some tests and go from there.
Burning oil doesn't really point to an injector issue in my mind.
One little test you can do w/out an AE is drive around get the truck to temp and then go sit in a parking lot. Put the truck in neutral and then put the pedal to the floor. Watch the tach. Look at 2000-2200rpm. Look for the needle to jump. If it does it's a good sign of injector issue.
I am not a fan of Ford "Technicians". They don't diagnose well a lot of the time. Are more R&R guys.
I'm sure we can get you on the right track. There is a lot of good info thus far.
A reman'd set of injectors are about $1100, stage 1's for $1200 IIRC from riffraff.
Will make a difference if you indeed have injector issues.
Good luck
Old Feb 25, 2013 | 10:32 PM
brendanmitchell
Good luck
Thanks, man I appreciate it. I just don't have the money to be spending $1100 on injectors, I can't do it.
Old Feb 26, 2013 | 07:11 AM
Tugly's Avatar
Tugly
That helps. If you are mechanically inclined and have some tools, then getting the AE information will be useful. If you rely on others to service/maintain a Diesel with 1/4-million miles on it, well... something to factor into your decision-making process:
Old Feb 26, 2013 | 10:24 AM
JT250's Avatar
JT250
I live in Bethany on the opposite side of OKC. It is not too bad though only about 20 min. You got any free time this weekend?
Old Feb 26, 2013 | 10:36 AM
brendanmitchell
If I don't have to work this weekend, I'll be free. I don't have any insurance on the truck right now since it's just been sitting, so I'm not wanting to drive it very far.
Old Feb 26, 2013 | 10:44 AM
JMP E350's Avatar
JMP E350
Look at this ! Guy driving 20 min to help a STRANGER with another PSD ! Love it !
They should make jackets for this place like a motorcycle club! haha
Mitchell.... if you don't have free time you better make some !!! This is invaluable for you right now!! Just sayin ...
Old Feb 26, 2013 | 10:58 AM
brendanmitchell
I'll make some, then! Thank you! Haha
Old Feb 27, 2013 | 07:58 AM
  #28
JT250's Avatar
JT250
Pm sent.......
Jbrown8988
107
Jul 20, 2011 04:07 PM
gmhorse
Jan 27, 2010 06:41 PM
whybnormal
Jan 27, 2009 05:55 PM
bowedup2003
Apr 17, 2006 09:39 AM
68Mercury250Ranger
Nov 6, 2005 07:23 PM
