Bad Injector?
Old Feb 25, 2013 | 02:13 PM
brendanmitchell's Avatar
brendanmitchell
Bad Injector?
Ok, guys, it's been a while since I've posted on here, but I finally had my truck looked at by an actual Ford diesel mechanic. I put on a new oil filter, and did my own oil change (Rotella 15w40), we started it up with it hooked up to his computer, and noticed that it was burning a decent amount of oil. At that same time, a misfire or something showed up in cylinder number 5. So, he was thinking that it could be a bad o-ring, bad injector, or in the worse case scenario, a hole somewhere causing the oil to leak into the fuel system? I got ahold of another mechanic who said that he was pretty positive that it was a bad injector on cylinder 5. Have any of you guys ever had this problem, and what were the symptoms you had? It's causing mine to have a delay in the start/hard start depending on temperatures outside. Do you guys think I should just go ahead and buy a new injector, and have it put in, or should I sell the truck? I'd love to get it fixed up, because it's a 99 and has a lot of potential. If you need more info just go ahead and ask me.
Old Feb 25, 2013 | 03:08 PM
JT250's Avatar
JT250
No need to sell it. Did the mechanic do a buzz test? Did he do a CCT test. Did he look at rotational velocities? Those wont absolutely diagnose a bad injector but they can get you close . Bad o ring would allow fuel to mix into your coolant that you would se in the degas bottle. Have you done the 50cent mod?
Lot of testing needed before replacing that stick.
Old Feb 25, 2013 | 03:17 PM
brendanmitchell
All I know is that he hooked his computer up to it, put the pedal to the floor and it just blew white smoke. Said there was a code that popped up for a misfire (I believe) in cylinder 5. Said that it could be just a bad o-ring, or possibly the injector. What's the 50cent mod? Please, explain.
Old Feb 25, 2013 | 03:23 PM
Tugly's Avatar
Tugly
There are too many possibilities without popping the top and inspecting parts. I had a loose #8 injector once that was making 6 and 1 look bad on the breakout box test. A tired O-ring will fit everything you describe, but so would a loose injector hold-down bolt... or a combination of the two... or a loose connector... or, or, or.....
When I had injector problems, I ultimately pulled them out and inspected everything. I knew pulling them would render the O-rings useless, so I ordered new O-rings from Riffraff Diesel before I started my work and the new O-rings solved some problems. The holes need to be cleaned out before putting the sticks back in because I found O-ring residue stuck to the walls.
If you hire a mechanic to do your repair work, it can get costly to "hunt and peck" at a problem like this. If your truck has over 200K miles, it's about due for the whole batch of injectors to be replaced and it's far cheaper to do this just once. So... there is nothing on the market today that matches the simpler and more durable engine that is the 7.3L, but it could be due for some maintenance. What would you replace your 99 with that would spare you the possible expense of updating your truck?
Old Feb 25, 2013 | 03:29 PM
brendanmitchell
Man, I really don't have the money to be replacing all 8 injectors. The engine only has 40k on it, so I figured I'd just replace the one. And, I'd just have my 03 Mazda to get me around. It's dependable, and good on gas, I love it. This sucks...
Old Feb 25, 2013 | 04:07 PM
Tugly's Avatar
Tugly
40K? Disregard. Rebuild or original miles?
Old Feb 25, 2013 | 04:12 PM
brendanmitchell
Rebuild, is what I was told. The guy who had the truck is a mechanic, and had it rebuilt with stronger internals.
Old Feb 25, 2013 | 04:17 PM
pin8246's Avatar
pin8246
Your told? That leaves a lot of things up in the air on what it could be. I dont have experience on this subject, but put where you live, rough location works, and there maybe somewhere near you with an AE that can point you in a better direction. These guys are very giving on here when it comes to helping another out. Good luck.
Old Feb 25, 2013 | 04:24 PM
brendanmitchell
I'm in Oklahoma City, Tinker AFB to be specific. Thanks.
Old Feb 25, 2013 | 04:48 PM
Crewcab Turbo's Avatar
Crewcab Turbo
What's the original miles on the truck? New motor does not mean new injectors. Odds are the injectors, most sensors, and hpop are original to the truck.
Old Feb 25, 2013 | 04:59 PM
brendanmitchell
Truck has 250k
Old Feb 25, 2013 | 05:10 PM
Crewcab Turbo
As Tugly said already, 200k+ miles is an average time to need new injectors. If those are the original injectors, I would replace them all. Your motor was rebuilt at 210k, most likely your injectors are original unless they were damaged by the original motor failing.
Old Feb 25, 2013 | 05:13 PM
brendanmitchell
The motor was rebuilt at 210k, and I'm not sure why. I didn't buy it from the person who did the rebuild. Sounds sketchy, I know.
Old Feb 25, 2013 | 06:01 PM
Tugly's Avatar
Tugly
So... you just want to get this running good enough to put on CL? Do you have a need for a bad-*** diesel, but maintaining it is too costly? Did this look appealing and you really like it, but you don't have the resources or the need for such a beast? Am I warm on any of these? This is not prying, this is my style of trying to learn what you really want to do about the truck and there are plenty of good people here to offer up useful input. Our input will be based on your true motivation.
Old Feb 25, 2013 | 07:27 PM
JT250's Avatar
JT250
Truck has 250k
I live in OKC I think I am the only one with AE around here.
If you want we can try to meet sometime to.check it out.
Maybe these guys will make a list of stuff to loom at so I don't miss anything.
