E4OD, lost 4th gear
Old Feb 25, 2013 | 08:07 AM
northerndave's Avatar
northerndave
E4OD, lost 4th gear
I had another post but I have since learned more accurate detail (like which trans I have lol!)
I just picked up this truck.
1990 F350, crew long box, 4x4, 460/E4OD
On my way home with the truck I lost 4th gear.
I was not towing anything, running unloaded on flat land with the cruise set at 60mph. All the sudden I had a growl from what seemed like the front of the truck, the things that flashed through my mind where axle related. I touched the brakes to cancel the cruise. The sound lasted for a few seconds then it was gone, I pulled over along the road to look things over, nothing was leaking, nothing appeared broken so I got back in and took off. But I never got 4th gear again. It will attempt 4th but it seems there's nothing there. I get a little spike in rpm, like a quick slip of the drive force and a 150-200 rpm spike on the tach then back down and it's still in 3rd gear.
4.10 gears, I'm running about 2650 rpm at 55.
I had been running maybe 2300-ish at 60 mph before I lost overdrive.
When I let off the gas at cruise speed the driveline does spin the engine, I seem to be locked up in the torque converter.
That's really all I know right now. No flashing light on the OD cancel button.
Looks like a rebuild runs around $1250, is this my best bet or is there something I can check for inside the magic gear changing device known as "auto transmission"?
(can I pull the pan and see anything that I can fix?)
Thanks.
Old Feb 25, 2013 | 05:02 PM
northerndave
lost everything now, junk.
No forward, no reverse, just sick noises.
Sick chunky transmission chunky stew noises.
And now I'm sick...
Old Feb 25, 2013 | 07:50 PM
jroehl's Avatar
jroehl
Unfortunately, that red thing out front probably has a lot to do with your tranny troubles. Sorry, dude--been there several times (though not on a just-purchased vehicle), it's never a good feeling.
Jason
xxtavixx
15
Jun 23, 2007 05:41 PM
xxtavixx
Jun 22, 2007 10:52 AM
kgk
Feb 23, 2005 10:01 PM
indocat
Dec 1, 2004 09:40 PM
93_Lightning
Aug 30, 2001 12:41 AM
