Wandering problem gone!
Old Feb 25, 2013 | 07:58 AM
m.i.nutz's Avatar
m.i.nutz
Been chasing this problem for a long time, ball joints, sway bar bushings and links, tires, alignment, etc. Turns out it was the REAR brakes causing the problem all this time, changed out the calipers and rotors. Going straight now!
Old Feb 25, 2013 | 08:56 AM
sean23johnson's Avatar
sean23johnson
That is good to know!! I have had a pass side pull in my truck for quite some time. Greased the pins, flushed the brake fluid and it still pulls!!! Maybe I should look at the rear??
Did yours pull all the time or just under braking?? Mine does it all the time.
Old Feb 25, 2013 | 10:24 AM
Tugly's Avatar
Tugly
My experience: You don't need to brake. Stuck rear slide pins do all the braking for you.
Old Feb 25, 2013 | 11:57 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Worn front hubs were causing a good portion of my wander problem.
Old Feb 26, 2013 | 06:45 AM
m.i.nutz's Avatar
m.i.nutz
This truck would go in both directions, not while braking.
Capt.Schenk
Feb 9, 2024 07:57 AM
ymurf
Sep 26, 2018 02:55 PM
RAY1986F150
35
Jun 21, 2011 02:03 PM
Thunderduckie
Oct 8, 2010 11:34 PM
gowers
Nov 22, 2004 02:14 AM
