Modular V10 (6.8l)
02 v 10 not statring
Old Feb 24, 2013 | 10:00 PM
stan'37's Avatar
stan'37
I go to start the motor, and it just spins over no fire whatsover. Out of desperation I shoot a liittle starting fluid in the intake, and it statrs and runs fine, and restartes fine. The motor has 38,000. What would cause it to not start the first time withour the starting fluid? I don't like to use the stuff, but I did. Any thoughts? Stan
Old Feb 24, 2013 | 11:57 PM
jh818's Avatar
jh818
You have fuel delivery system problems most likely. First thing to check is if the fuel cutoff switch is engaged. If ok, then change your fuel filter if you haven't done so.
These are the 2 basic and simple things to try. If after those 2 and you still have no fire, then you need to get a fuel pressure gauge and see if you're getting pressure on the fuel rail. It could be something as simple as a fuel pump relay all the way up to a fuel pump problem.
edit: Just read over your post and realized that it runs well after the starting fluid. Maybe the fuel pump is not priming the pressure when you turn the key?
Old Feb 25, 2013 | 02:43 PM
stan'37's Avatar
stan'37
I changed my fuel filter, it was quite dirty. I got a filter, and it was too big around, the store said it was the correct one for my v 10. . Come to find out the one in my v 10 is the same as the F150. I think much too small for the job. I will be changing it more often. Wonder whay they used a small filter? Something I will never know I guess. Stan
coloradojeep1
Nov 23, 2017 06:57 PM
Race4Fun82
Jan 21, 2014 08:42 PM
thefordlane
1983 - 2012 Ranger & B-Series
May 5, 2010 07:05 PM
1986fordrangerman
1997 - 2003 F150
Mar 3, 2009 03:44 PM
barca_texas
Oct 27, 2005 01:25 AM
