learned something new about tunes.....
Old Feb 23, 2013 | 12:00 AM
Fulthrotl's Avatar
Fulthrotl
just bought a sct tuner and three of matt's tunes....
unlimited tow, 8k tow, and a SRL - (minus) which is
a tune they have written for heavy trucks, less peak
HP and more torque on the bottom, and less heat.
if i'm gonna tow, i'll have to switch to one of the tow
tunes, but yahoo, i can run SRL, which is about double
the horsepower gain of the 8k tow tune.
i need to find or make an adapter to fit my thermocouple
hole... the banks thermocouple that was removed is a larger
hole than most thermocouples....
figures.
i'll let ya all know how it works dragging a 5 ton boat anchor around.
Old Feb 23, 2013 | 08:38 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The SRL - sounds like a good daily driver for normal trucks too.
Similar to Vivian's Looney Tune and Looney Wild. But I had her make me a Looney Mild.
Josh
Old Feb 23, 2013 | 10:53 AM
dlibson's Avatar
dlibson
What's your truck fulthrotl?
I run the 100 HP Edge tune on my F450. It makes it move!!!
Old Feb 23, 2013 | 02:48 PM
MisterCMK's Avatar
MisterCMK
SRL+ is a great daily driver tune.
Old Feb 23, 2013 | 04:24 PM
MC5C's Avatar
MC5C
I'd like to know how the SRL Minus tune works with an automatic transmission. The AT always downshifts to raise RPM to the power producing range, ignoring the torque producing range, so wondering what the SRL Minus does to shift points to let the increased low RPM torque actually get used. Different story with a manual trans, obviously.
Old Feb 24, 2013 | 06:48 PM
Fulthrotl's Avatar
Fulthrotl
2006 E-350 van, stock turbo, intake, and exhaust.
had a banks IQ and economind on it, but the IQ
started failing, the economind wouldn't communicate
with it, and the banks speedbrake, which was the
original reason i bought the banks unit, banks was
never able to come thru on their promise to supply
one that worked on my van, after they said it would,
and installed the IQ for me.
so the only thing on the van from banks is the sticker
on the back, until i take it off. i'm underwhelmed with
banks products at this point.
my mechanic has a large box filled with banks crap
that customers have removed and throw away.
at least i removed it before it hosed the tranny. that
seems to be a hallmark of banks tuners.
Old Feb 24, 2013 | 07:50 PM
mstiles19's Avatar
mstiles19
Just wondering do you have studs?
Old Feb 24, 2013 | 07:58 PM
the_auto_tech's Avatar
the_auto_tech
Banks stuff seems like ****.
Old Feb 25, 2013 | 07:33 PM
Fulthrotl's Avatar
Fulthrotl
yep... arp's, OEM head gaskets, heads done, and stellite valve seats.
loaded up matts tune.... he does have a SRL - tune, but it won't work
on a E-350 diesel powertrain....
he sent a performance tow tune instead.... 75hp.... after playing with
it, here's the email i sent to matt and lars.....
holy ****! that works well, for launching a barge!
pulling away from a corner will chirp the tires a bit,
but it has tall gears, and the weight on the rear axle
is 6,100 lbs, with an open diff....
seat of the pants is that the banks on level 6 probably
fueled the engine a bit more, but the trans shifted about
the same as stock, so thats probably not a good thing....
i'm less than thrilled with the banks, you probably guessed.
a 30-60 roll on, your tune is excellent... very little smoke, and nice
crisp shifting.... and it hauls ***..... i'll take lar's advice, and not
check the milage till i calm down after a couple tanks....
stock was getting 12.5-13 composite milage, and 19-20 at 60
on flat freeway... will see what the fuel consumption is like
after the "new fun toy" phase wears off... i suspect it's gonna
be about 6 mpg for the first tank....
another happy camper. no dtc's after upload....
thanks, both of you.
randy
so, that is where it's at now. i need to go out and play
with my 10,500# bracket racer...
JoshC017
6.4L Power Stroke Diesel
25
Apr 17, 2020 09:42 AM
scameron
May 18, 2009 03:33 PM
mtgrzlyman
Mar 2, 2006 03:44 PM
mtgrzlyman
Sep 24, 2005 09:58 PM
metoo
Computer Chips & Tuners
Jun 9, 2004 05:54 PM
