split rim with no split
Old Feb 22, 2013 | 06:21 PM
garthr's Avatar
garthr
i have a 20" 5 hole budd wheel that is 2 piece but the ring thats normally split is not. does anyone have info on how to disassemble? its pretty rusty, and may not be worth the trouble, but would keep me from having to find another one.
garthr
Old Feb 22, 2013 | 11:47 PM
GB SISSON's Avatar
GB SISSON
The ring is round on the outer perimeter, but sort of oval on the inner diameter. You need to rotate it to the narrow part and get it started over the flange. You'll see. It has a place where it comes off......
Old Feb 23, 2013 | 05:10 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
It's called a Firestone "RH" in all likelihood. Like Gary said there are two indented areas on the inner lip that must be squeezed over and past the rim to remove or install it. Not always an easy thing to do, don't put too much pressure on the tire iron because if you bend it you are SOL, and please be sure there is no air in the tire when you begin. Here's pictures of a similar ring. Stu
Old Feb 23, 2013 | 01:55 PM
garthr's Avatar
garthr
thanks for the answers, the tire was put on, so there must be a way to remove. the pic looks like what i have, minus lots of rust. i think a split would have made it more simple, but ill give it a go. some folks i asked in my area had no idea what i was talking about. one thought i may have a two piece like a combat rim that bolts together in the middle.
thanks again,
garthr
Old Feb 23, 2013 | 06:35 PM
85e150's Avatar
85e150
Last edited by 85e150; Feb 23, 2013 at 06:55 PM. Reason: Delete incorrect info, see post 6.
Old Feb 23, 2013 | 06:48 PM
truckdog62563
But they DON'T call these widow makers. These are the plain "RH", not the "RH-5°". These are lock ring style with the general consensus, to my view, being that they are safe to use. Safe, that is, with appropriate precaution and use of a cage while inflating, etc. I've quizzed quite a few shops about wheel service and have not had one decline to work on these, which can't be said for the "RH-5°". Stu
Old Feb 23, 2013 | 06:54 PM
85e150's Avatar
85e150
Oooops, thanks for the catch.
twozzie
Jan 3, 2016 08:30 PM
HermanTheGerman
1947 and Older Ford Trucks
May 17, 2015 06:42 PM
95stepside
Jun 3, 2014 07:30 PM
sc0r1a
Sep 27, 2011 03:37 PM
Americanmadeford
May 22, 2007 10:07 PM
