Replacing Glow plugs.
Old Feb 25, 2013 | 08:21 AM
  #31
Chevy_Eater's Avatar
Chevy_Eater
Originally Posted by Dieseldriver13
OK now I am thourghly confused, FORD DIESEL GLOW PLUG RELAY/CONTROLLER$31.00 or
glow plug relay controller for over $100.00. One looks like a starter solenoid and one is totally different. Its on top of the motor under a plastic case. Which one do I need???
Like Mac pointed out earlier, if your wait to start light isn't coming on that usually points towards the controller. The controller tells the relay when to turn on and for how long. When the relay activates it turns the GPs and the WTS light on.
Might be a good idea though to do some diagnosis before throwing money at it:
Glow plugs, 87 thru 94, new style system
Old Feb 25, 2013 | 09:33 AM
  #32
Dieseldriver13's Avatar
Dieseldriver13
The controller is on the pass side fender or on top of the motor? Does it look like the starter relay or the one in the plastic box?
Old Feb 25, 2013 | 09:52 AM
  #33
Phy's Avatar
Phy
The controller is on top of the motor, back by the firewall. The relay is mounted on top of the controller, with a rectangular plastic cover over the whole works.
Go through glow plug thread at the top of this forum to troubleshoot.
Old Feb 25, 2013 | 12:04 PM
  #34
Red454sedgwick's Avatar
Red454sedgwick
If your truck is trubod the controler is on the passeger side valve cover. It is a starter relay on top of a black plastic box
Old Feb 25, 2013 | 04:00 PM
  #35
Dieseldriver13
Ok thats where i get confused. Both are the controller. I want the starter relay looking one that is in the glow plug thread that I have read twice. Why is there two different GPC relays? Who can I get the correct good quality one from? I dont want one that will fail after 5 starts.
Old Feb 25, 2013 | 07:27 PM
  #36
Chevy_Eater
Okay, this is the GP relay:
On your system it mounts to the top of the GP Controller. Here is the relay on the controller:
This is a pic of under the hood of my truck, passenger inner fender. I have the old system:
You should have the starter relay on yours, yellow circle, you should not have the GP relay mounted on the fender like mine, red circle. Your relay is mounted to the top of the controller under that plastic guard on the rear of the engine behind the air cleaner.
Old Feb 25, 2013 | 07:35 PM
  #37
Chevy_Eater
As far as where to get it, Ford or IH would be best. Rockauto shows Airtex (run away from anything Airtex) or Delphi. (I have no experience with Delphi.)
Oreily's shows they can order the Motorcraft for $193:
Motorcraft DY1128 - Glow Plug Switch | O'Reilly Auto Parts
And that's for the controller with the relay.
MyTruckMax
Jun 13, 2011 05:06 AM
cowmilker08
19
Jul 31, 2009 11:22 PM
michaelbrainardatwor
Jan 4, 2008 07:29 PM
fordtks
Dec 7, 2006 06:47 PM
machnist1
Nov 10, 2006 03:32 PM
