deanj, thanks for the info. Sounds like you may have had the same problem. PB blaster is great stuff. Does anyone use never seeze? Actually, I think I over torqued when I put them in.
i do the clean and pb routine also. let it sit overnight, and then spray it again till you can crack them loose. never seize is a must use. only tighten them finger tight. i think the book calls for 15 inch pounds or something like that.
