Changing Glow Plugs
Old Jul 27, 2009 | 08:50 PM
cowmilker08's Avatar
cowmilker08
Changing Glow Plugs
Ok tomorrow after i get my wisdom teeth pulled I am going to replace the glow plugs in the ol' girl. So what specs do I need to know? And also any tricks or tips would be good. I've never had the VC off and i know that they can be somewhat of a PITA, but i heard awhile back that was some special trick to getting them off.
Old Jul 27, 2009 | 09:31 PM
MustangMatt96GT's Avatar
MustangMatt96GT
Good luck doing that after your wisdom teeth... LOL. I was out for a few days when I had mine done.
Old Jul 27, 2009 | 09:36 PM
cowmilker08
Well it may be wednesday when i get around to it, well see. LOL. My father-in-law was eatin a Big Mac an hour after gettin his pulled. I'm hoping to top it with this.
Old Jul 27, 2009 | 09:39 PM
oldbird1965's Avatar
oldbird1965
I just used a 1/4" 10mm deep socket and prayed that they would come out without breaking. Don't force them, I've heard horror stories if they break off and fall in. Use anti-seize on the new ones when you put them back in.
Old Jul 27, 2009 | 09:43 PM
cowmilker08
i thought they took 11mm deep well.
What are the odds of breaking one off?
Old Jul 27, 2009 | 10:15 PM
don77's Avatar
don77
if there not autolites you should be ok from what ive herd
im fixing to do mine hope i dont got that problem
Old Jul 27, 2009 | 10:18 PM
cowmilker08
Oh I went to Ford to get them, talked 'em down $9 per plug too.
Old Jul 27, 2009 | 10:19 PM
MustangMatt96GT
I plan on doing some injectors and glow plugs on my truck before the summers end... take some pictures.
And it must be the white truck, regular cab long bed thread.... lol
Old Jul 27, 2009 | 10:23 PM
cowmilker08
I can do that for ya.
Well that's becuase they are the best, so **** the rest, BWHAHA. Just Kiddin
Old Jul 27, 2009 | 10:27 PM
MustangMatt96GT
I honestly love my truck! Its perfect size to go wheeling in, mudding, climbing in, and it pulls my trailer just fine... now if only it had more power and a 4 inch lift (both of which are coming). I do kinda want to get a crew cab just to beable to drive more than two others around with me... and I used to think white looked gay on trucks, but now I love it... maybe because mine is normally covered in mud... IDK.
Old Jul 28, 2009 | 07:06 AM
Talyn's Avatar
Talyn
Somebody was saying get ZD-11 glow plugs.
I mighta got that wrong.
Old Jul 28, 2009 | 07:57 PM
oldbird1965
Its been three years, maybe it is 11mm. I don't know the odds of breaking, I just read about it on here. Sorry I'm not much help.
Old Jul 28, 2009 | 09:59 PM
cowmilker08
Well about the time was i was gettin ready ready to start working on it the vicotin made me sick. So I guess i'll get started tomorrow.
I haven't heard of ZD-11 glow plugs before. But I got mine from ford so that should be good, I'd at least think so.
I don't really like white trucks either, but for some reason they look awesome on this body style.
Old Jul 28, 2009 | 10:49 PM
Gobstopper909's Avatar
Gobstopper909
cowmilker, as long as they say beru on them they are fine. use a 13mm swivel socket and either a 3" or 6" extension in 3/8" drive for your vc bolts. the back ones are a little tough but the swivel should make it easier. you will have to remove the ac dryer (2 bolts) to get the pass side vc off. use 10mm deep with a 3" extension in 1/4" drive for the glow plugs.. might have to play with the extension to keep it away from the push rod/rocker arm from binding against the socket. GO VERY SLOW in removing the old ones. if you feel bind-age...STOP!spray with your favorite boob lube. repeat. try not to sweat this. youll be fine. JUST TAKE YOUR TIME. just like glenn said, coat new ones with never sieze; install to 14 ft. lbs. make sure all your electrical connections are on and no burnt pins while youre in there.
maybe throw a set of injector o-rings on while your in there? not sure how youll be feeling with your teeth. wish you luck let us know how it goes.
Old Jul 29, 2009 | 07:49 AM
oldbird1965
You don't have to remove the ac dryer but it helps to make room. I used the 1/4 inch swivel, did a hand stand, bent my elbows, flexied my butt, swore and it came right out lol.
