Transmission question
Old Feb 22, 2013 | 09:16 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by BLADE35
Mine Does its got a range sensor MY SGII is already setup for it
You mean to tell me DB Dont have this ??????????LOL
What is the x-gauge code for gear selector position?
And not to "LOL" but Ken of DashBoss wrote the original script for both Edge and Scangauge FYI
Josh
Old Feb 22, 2013 | 09:21 PM
BLADE35's Avatar
BLADE35
I will have to find it
I know its programed in my truck I can get tommorrow
I wont go so far as to say its programed to have the same Values Per Ford spec IIRC the Code needed adjustment
But I do get a Diffrent Volt Value per PRND321
Old Feb 22, 2013 | 09:27 PM
Bullitt390's Avatar
Bullitt390
So it doesn't translate into actual letters and numbers, just a voltage value?
Josh
Old Feb 22, 2013 | 09:36 PM
BLADE35's Avatar
BLADE35
JUST a diffrent voltage for each range PRND321
Then the other Gear shows 12345
Old Feb 23, 2013 | 09:02 AM
Rusty Axlerod's Avatar
Rusty Axlerod
I haven't used it but here's one you can try:
Gear
TXD: 07E12211B3
RXF: 0462051106B3
RXD: 3008
MTH: 000100010000
NAM: GER
Old Feb 23, 2013 | 09:43 AM
CPB1's Avatar
CPB1
I have not used it either. From my notes. It looks like the math is 1 digit different from Rusty.
Gear (Transmission Gear)
TXD: 07E12211B3
RXF: 0462051106B3
RXD: 3008
MTH: 000100020000
NAM: GER
Old Feb 23, 2013 | 02:02 PM
BLADE35's Avatar
BLADE35
Josh
Well Josh thats where I mentioned the SGII Code needed Work
It just shows Basic Voltage Which Sometimes I prefer because you are more likely to get an Accurite Reading Since Everything the PCM Sees is in a Voltage reading
Basicaly when I asked James D to try to make a Gauge for it all I was Concered about was something that shows a Diffrent reading (VALUE) per Each PRND321
My Intensions at that time were just to have something that I could check the Trans Range sensor in the Case of a NO-START Since the PCM will NOT let the Starter Engauge if the Range sensor is in any other Location then Park or Nuetral
So when this thread came up and Mark K. Mentioned adjustment I wondered if Seeing the Range sensor value would Shed some light on his problem. I assume he is Very Close in adjustment because he dont say anything about a NO-Start
For the Other Guys
AS for these other Gear codes these Guys have this Gear Gauge is NOT The SAME as Range Gauge
Jimax
6.7L Power Stroke Diesel
15
Jun 30, 2013 04:17 PM
HIPCHECK
Jun 14, 2010 07:49 PM
Danger_Dave
Feb 23, 2009 11:18 AM
Sudsrat
1997 - 2003 F150
Oct 17, 2008 08:11 AM
FTE Ken
Jul 12, 2002 11:09 AM
