blower motor problem
Old Feb 21, 2013 | 11:03 PM
bike_guy123's Avatar
bike_guy123
When I turn the switch through the speed settings, I get nothing. NO AIR MOVEMENT or blower actuation. I have checked all the relays and fuses and and all are fine. I pulled the blower motor out and hooked it up to a power source and it runs just fine. I put my Multimeter on the connections, but that is where I draw the line. I have a multimeter, just dont really know what I am doing or looking for.
Any help from here would be great. I am guessing it is the switch itself or some sort of resistor problem, just don't know where to go from here. Thanks again in advance for any help from anyone.
Oh, by the way...it just happens to be the biggest snow of the year and the plow needs to be pushing...sort of hard to do without a fan and defrost! MIKE in MN
Old Feb 21, 2013 | 11:37 PM
crop harvester's Avatar
crop harvester
do you have power & ground at connection going to the blower moter.
Old Feb 21, 2013 | 11:41 PM
hydro man 17's Avatar
hydro man 17
Sounds like the switch to me as long as everthig else cheks out as you said. Never been into one on these trucks but you should be able to remove the switch and check the contacts for the different resistance values. (Ohms scale on a lower setting 1 - 5K)
Old Feb 21, 2013 | 11:53 PM
crop harvester
I would do a search here there was info before on your problem.far as I know you got switch,resistor,blower moter,wires to test.
Old Feb 22, 2013 | 01:17 AM
bike_guy123
I am about 99% sure it is the switch....I will do some checking with a test light in the morning....if it is the switch...where do I go to get one....the bone yard or a place like auto zone or Orielly's?
Old Feb 22, 2013 | 08:38 AM
Cmedic's Avatar
Cmedic
I have personally had good luck with rock auto.com for my switches when needed for some of my other vehicles.
Old Feb 22, 2013 | 08:40 AM
empiretc's Avatar
empiretc
replace the blower motor resistor.
Old Feb 22, 2013 | 05:41 PM
bike_guy123
Got it! Resistor it was....thanks for the help.
Old Feb 22, 2013 | 06:13 PM
empiretc's Avatar
empiretc
glad you got her going.
skidaddy
Aug 31, 2021 12:03 PM
ScottyC50
Jun 28, 2021 07:12 AM
Tenderpaw
May 29, 2012 09:15 PM
80s Trucker
Jul 2, 2010 09:01 AM
Qautchat
Aerostar
Jan 16, 2008 11:23 PM
