Easy blower fix?
Old Nov 25, 2018 | 05:57 PM
ScottyC50's Avatar
ScottyC50
Easy blower fix?
I have a 1979 f150 Lariat. The blower motor on my truck is the same when the blower switch is on the 3rd and 4th settings. Is this an easy fix....is something disconnected or do I need to look at the voltage to the switch? Any ideas would be appreciated....thanks!
Old Nov 25, 2018 | 07:50 PM
meangreen92's Avatar
meangreen92
Sounds like a bad resistor.
Old Nov 25, 2018 | 07:51 PM
ScottyC50's Avatar
ScottyC50
Thanks...Ill check it out
Old Nov 25, 2018 | 08:41 PM
dlburch's Avatar
dlburch
do the first two switch positions seem normal?
when you switch to the third and fourth settings, can you tell if the blower is running at full speed, or normal speed for the third positions?
When you switch to the hi (fourth) position, the blower resistor is bypassed.
Old Nov 26, 2018 | 03:24 PM
ScottyC50's Avatar
ScottyC50
The first 2 seem normal. The 3rd are 4th are identical speeds.
Old Nov 27, 2018 | 04:36 AM
four-sixty-power's Avatar
four-sixty-power
I seem to recall that if the resistor goes then it defaults to only running at full speed. So in this case I would suspect your switch is faulty.
Old Dec 24, 2018 | 07:14 PM
ScottyC50's Avatar
ScottyC50
Thanks - an easier fix than i thought!
Thanks to everyone who responded. I did order a new blower switch. It came in, and when I went to install it, I noticed the black wire from the coupling was pulled out a bit. I pushed it back, and voila! I have all 4 speeds on the blower. I guess I'll just keep the switch - you can never have enough spare parts for a 40+ year old truck. Thanks again...
Old Jun 27, 2021 | 09:00 PM
John R. Thomas's Avatar
John R. Thomas
Need current to my heater/a.c. blower
I looked way back for my previous request for help....not finding it. I found the pictures of the short fuse panel....like mine with 5 fuses. The shorty has no current either side.
It had duel tanks with the valve lever on the floor and a toggle switch on the dash for the gauge. No relay for the blower. AND no current at the switch and the resistor.
The switch has high and 2 lower speeds. Off is on the lower lever. With an orange & yellow wire going to the high speed on the switch and 2 of them at the resistor.......all dead,
I wrote another new thread this week. Perhaps that's the jinx of being a Viking Edition. I'm not able to crawl under the dash feeling where the harness go. I'll try again tomorrow.
Old Jun 28, 2021 | 07:12 AM
mudbogger2's Avatar
mudbogger2
That is where your problem is. No power to the fuse means you wont get power anywhere else on the circuits.
CNC
Dec 28, 2016 06:08 PM
hotrod351
Jul 29, 2016 12:50 PM
80s Trucker
Jul 2, 2010 09:01 AM
blloyd
Nov 1, 2009 07:32 PM
91Van
Oct 17, 2003 12:33 PM
