valve adjustment help
Old Feb 21, 2013 | 08:19 PM
jaye's Avatar
jaye
I just finished rebuilding my 289 and have a question on how you guys adjust the valves. When I adjust the valves I tighten them until the pushrod still can spin.
Thanks in advance
Old Feb 21, 2013 | 09:19 PM
fatfenders's Avatar
fatfenders
I assume you have adjustable rockers since you are asking this question? After putting the cam on the base circle, I tighten until all slack is removed (pushrod will still spin easily), then preload lifter another 1/2 turn for a street motor, 1/4 with rowdier cam profiles that frequently see higher rpms.
Attached are instructions from Ed Curtis of Flowtech Induction. He is a very respected custom cam guy. Not as simple as some instructions you may find, but this method gets you on the base circle everytime.
File Type: doc
RadioControlGuy85
Apr 10, 2014 10:38 AM
1bad67sbf
Mar 11, 2010 04:39 PM
wagontrainer
Mar 11, 2008 09:56 AM
s9bryant
Jun 13, 2005 10:41 AM
hey_beaver
Jan 3, 2005 12:00 AM
