Adjusting valves
Old Mar 10, 2008 | 04:42 PM
wagontrainer's Avatar
wagontrainer
Adjusting valves
I was wondering if someone could tell me the correct procedure for adjusting the valves on a 1989 302 with a Roller Cam?
Old Mar 10, 2008 | 09:32 PM
Beanscoot's Avatar
Beanscoot
There is no adjustment.
Old Mar 10, 2008 | 10:29 PM
planethax's Avatar
planethax
No maitanance adjustment.
Are you setting up new lifterss/cam etc?
Does engine run currently?
Why are you looking to adjust?
Old Mar 11, 2008 | 07:06 AM
wagontrainer
W
Replacing Cam
Old Mar 11, 2008 | 07:47 AM
Conanski's Avatar
Conanski
Originally Posted by wagontrainer
Replacing Cam
Still should be no adjustment required. Did this motor have a roller cam to start with?
Old Mar 11, 2008 | 09:56 AM
planethax's Avatar
planethax
Ok, I read through AllData and Mitchell.
There is a Valve clearance check (similar to the old Chevy way)
However there is n o adjustment, if your clearance is out (.125" - .175") then you can get .060" over/under sized push rods.
So you just need to Torque the Rocker Arm Fulcrum bolt to 18 to 25 LBS FT
