RockerArm Question.
Old Apr 9, 2014 | 01:22 PM
RadioControlGuy85's Avatar
RadioControlGuy85
RockerArm Question.
hey guys,
question.
when installing the rocker arm assbly,do you torque them down with the valves open or closed?also dose it matter if there open or closed.
other question.
we bought new springs for the valves cause the cam called for it.so we installed them.but there was some .30 spacers on the old springs.we put those back.im wanting to know do we need to take those out? or will it be fine if they are left in there?
thanks
Old Apr 9, 2014 | 03:48 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
The lifter should be on the base circle of the cam when adjusting the rockers. Rotate the crank until the exhaust valve starts to open, adjust the intake rocker, then rotate until the intake valve starts to open and adjust the exhaust valve. Start with #1 and go through the firing order.
Whether or not the springs need shims depends on the installed height of the valve retainer and mfg recommended valve spring height.
Old Apr 9, 2014 | 04:35 PM
RadioControlGuy85
what do you mean about the base circle of the cam?
thanks for the help
Old Apr 10, 2014 | 10:38 AM
F-250 restorer's Avatar
F-250 restorer
Your cam manufacturer will have a recommended installed height. There is a specialized tool for measuring the height.
Adjusting the rockers, valve lash: Do you have pedestal or stud mount rockers?
The base circle is the opposite of the lobe. The lobe pushes the lifter up and down. Then the lope continues to rotate and moves past the lifter. Once the lope has moved out of touching anything, the base circle is holding the lifter.
rcfreed
Aug 21, 2015 03:03 PM
jaye
Feb 21, 2013 09:19 PM
mark1986F150
Dec 14, 2012 07:37 AM
cathode
Jan 24, 2011 01:31 PM
djmac
Oct 16, 2004 01:56 AM
